Old 11-23-2006, 10:14 AM   #1
terratravelr's Avatar
1974 27' Overlander
Merryman Station , California
toilet of the endless flow
greetings, all,
where is toilet water adjustments? I am assuming it must be in the foot pedal, that appears to be functional. Please elaborate
grazie
(I honestly perused other posts first !!!)
terratravelr is offline   Reply With Quote
Old 11-23-2006, 10:34 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
What adjustment? I have two pedals, one opens the trap door and water flows in. The other flows water in without opening the door. Press and hold as needed.......
Richard
Old 11-23-2006, 11:16 AM   #3
1974 27' Overlander
the one pedal opens the trap ok, but I am suspecting that the other pedal allowing water to fill the tank as needed is stuck.
Old 11-23-2006, 07:50 PM   #4
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, if it's an Aqua Magic, there are two possibilities.
One is that some debris is lodged in the area where the slide retracts and it's keeping the water pedal partially depressed. Pulling up on the flush handle will confirm this (and push whatever's in there further into the channel).
The other possibility is that the "ball valve" in the fresh water inlet is so worn that it causes the toilet to try to fill continuously. They can go bad all by their lonesome if pressure is kept continuously on the system.
Getting to it requires removing the toilet. There's a plug under the seat at top left that lets you reach the flange bolt with a long extension, and the other can be reached in the pedal area. It helps to have something like a plastic soda bottle to wedge in there to hold the pedals out of the way while you work on it.
The ball valve can then, if I remember right, be removed without disassembling the toilet.
And, in my opinion, this is why there should always be a shutf-off valve in the line going to the toilet.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 11-25-2006, 08:25 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
What exactly is it doing - someone here will have a cure.
Old 10-08-2007, 07:48 AM   #6
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Sounds like this is what happened to us this weekend.
Toilet would not stop running.
I cleaned the groove for shutoof valve, and it appeared to be closing all the way, but water just kept flowing.
Foot pedal were not stuck, spring were still attached.
I cycled pedal repeatadly in an attemp to get any stuck valves to close but no luck.
We got around it by turning off the water pump, but it sure was a PIA.
Did anyone find the problem and cure for this?
Is it the ball valve?
Thanx, Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 10-08-2007, 08:34 AM   #7
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
HI terratravelr, It sounds to me like your water fill valve needs to be replaced. If the toilet is still good in other respects, replace the valve. If the toilet is older and not in the best of condition, now would be the time to consider a replacement.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 10-08-2007, 08:41 AM   #8
1 Rivet Short
1989 25' Excella
Would this be the cause of continuous water flow?
Thanx, Bill
Old 10-08-2007, 08:49 AM   #9
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Since you will probably have to remove the toilet to fix, I also recommend replacing with a new one. There are several really nice porcelin replacements available and they are all an substantial improvement over the old plastic.
AirForums Custom Search
Janet H is offline   Reply With Quote
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 06:46 AM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
Toilet valve problem Charles Q Treichel Sinks, Showers & Toilets 1 09-04-2002 10:59 AM
