Old 08-28-2016, 07:10 PM   #1
2016 27' International
Estero , Florida
Toilet not holding water when closed
Evening everyone.
Our 27FB international is just 4 months old and the toiled does not hold water when seal is closed. We used to be able to slightly push down on the pedal and completely fill the bowl, and then drop an enzyme cleaner in, flush, and then repeat filling with water two more times to "prime" the system. Now it will not hold water. Black seal inside still wet with lube and not cracked.
Ugh.... Help much appreciated, as it feels like the white thing that moves is the part not making the connection
Thanks everyone!
Rich
KariRich is offline   Reply With Quote
Old 08-28-2016, 07:31 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I would lube the white thing and black seal again, after taking a toilet brush and cleaning anything that may be caught up under the black seal.
Doug and Cheryl
Old 08-28-2016, 07:45 PM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
X2
Plus...pour some vegetable oil in and let it sit overnight, (I used to use Olive oil).
Cheep wally-world rv antifreeze ruined ours years ago,(no longer put AF in the bowl when Winterizing...just Crisco),not a big deal to replace the flapper valve, but take pics of the mechanism. The instructions for ours were lacking.
I'd stop putting the enzyme tabs directly in the bowl to dissolve, most likely the culprit.
Good Luck..
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-28-2016, 07:55 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
If the stiff brush does not work you may need to clean the groove. Paper and waste can get impacted in there and stop the valve from completely seating.
Thetford makes a tool for cleaning out the groove that the valve blade slides in.
http://www.adventurerv.net/thetford-...r-pi-5136.html
I created a home made tool out of a flat screwdriver by heating/bending the end. Be gentle if you use the tool. I tied a string to the tool and wrap around my wrist to keep from accidentally dropping it into the tank.
Alan
Old 08-29-2016, 10:58 AM   #5
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I had the same challenge with my 2016 FC20. When I had it in for warranty work they repaired the gasket. Now it holds water just fine. I never could tell if it was the gasket or not because it looked like it was sealing as it should but apparently wasn't
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 08-29-2016, 11:08 AM   #6
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Ours gets finnicky sometimes.
If the trailer is in storage for a long time, sometimes the water seeps out (or evapoarates?) and once the seal dries it takes a while to get it sealing again.
First time this happened I suspected paper - or something - in the seal area and cleaned it out with a popsicle stick (using throwaway nitrile gloves!) That didn't fix it. I wound up putting some silcon dielectric grease that was in my toolbox on the flapper, and that seemed to do the trick!
Never had it apart, but I imagine you need to remove the whole toilet to get at it if you need to replace the seal.
Brian.
Ne
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-29-2016, 11:40 AM   #7
1977 31' Sovereign
Lynnwood , Washington
Sounds like the seal has dried out.
Get a tub of plumber's grease and rubber gloves. Turn off the water. Open the valve (hold it open with your knee). Lather the seal both top and bottom. As you lather grease, work the valve back and forth. Be generous with the grease.
While you're at it, inspect underside (lip) of seal with your fingers; remove all solids. Underside of seal must be free of all solids.
http://www.lowes.com/pd/Oatey-Plumber-s-Putty/4754110
BTW - Plumber's grease is an important part of your tool kit.
Tom
TomKirk is offline   Reply With Quote
Old 08-29-2016, 11:47 AM   #8
richw46's Avatar
Lexington , Kentucky
Tom
Never heard of plumber's grease; you mean plumber's putty? That's where your link takes me. I've used that in the house but it dries up in about a year, have to buy new stuff. I've used it to seal sink drains but never to grease anything.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-29-2016, 11:50 AM   #9
richw46's Avatar
I know that olive oil or vegetable oil will eventually go rancid. I've heard of people using mineral oil on things like cutting boards to season them and not have to worry about the oil going bad. Ever try mineral oil on the seal?
-Rich
Rich & Yvonne
2004 4Runner SE
Old 08-29-2016, 12:51 PM   #10
2006 19' Safari
East Greenbush , New York
It's really not hard to replace the gasket. But it is indeed early for it to have failed.
Been there, done that. Not hard, just messy (and yucky for the germ-o-phobes). There are repair kits containing the flapper gasket and the base ring seal.
But I would think you might want to ask about a warranty repair before diving in and replacing the seals yourself. Mine lasted about 7 or 8 years before it refused to hold water.
Matt
2006 Safari Bambi 19'
2017 Silverado LT Z71 Double Cab 1500
heitkergm is offline   Reply With Quote
Old 08-29-2016, 12:59 PM   #11
dkottum's Avatar
I use silicon grease to lube the valve, doesn't wash off or dry out, long lasting.
Doug and Cheryl
Old 08-29-2016, 01:09 PM   #12
Plan-B's Avatar
2016 26' Flying Cloud
2016 25' Flying Cloud
1997 21' Excella
Watervliet , Michigan
I can't say enough good in how well this product works for rejuvenating dry and/or old leaky toilet seals and tank valves. After winterizing I always poor a fair amount in black/grey tanks and pour in toilet bowl so it covers about 1/2" deep in bowl. It is silicone based so it peneteates well and does not damge your seals. Be careful in over doing it with certain kitchen oil based products. The wrong kind and too much will overly soften your seals making them non functional. I had a 21 foot AS for 19!years. In its later years I had your same issues. After usining this product , she functioned perfectly as if new for 8 more years, till I sold her. My new AS gets regular treatments. Really sold on this stuff. Link to product description:
http://m.campingworld.com/shopping/i...nt-20-oz-/4179
Greg
2016 RAM 2500 6.7L Cummins, 4WD, Crew, Rear Air
Plan-B is offline   Reply With Quote
Old 08-29-2016, 01:20 PM   #13
1967 26' Overlander
Spartanburg , South Carolina
NOT PLUMBER'S PUTTY.....Plumbers Grease....The best brand I have found is ACE Hardware. As to the lubricating the toilet valve, that would work. You can also find a product at NAPA auto parts stores called SilGlide, a silicone grease. I use it also on my rubber window seals which are now starting to show some cracking after 50 years.
Jacob D is offline   Reply With Quote
Old 08-29-2016, 01:38 PM   #14
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We have used hand lotion to lubricate a dried out toilet flapper seal...anything that will help lubricate will work...when its clean, we pour a bit of cooking oil and leave it in the toilet bowl for a couple of hours to soak. We put gloves on and use a toothpick to get into the groove that the flapper fits into (don't drop the toothpick!) ... Be sure to clean the underside of the gasket...it gets calcium deposits which keep it from sealing properly. When in storage we check the toilet periodically to make sure the water in the bottom of the bowl hasn't evaporated, especially in our dry climate in AZ.
TB & Greg and Abbey Schnauzer
#3954
New Toilet and Holding Tank rangebowdrie Waste Systems, Tanks & Totes 0 08-17-2009 08:52 AM
adding a toilet and holding tank to a 54 FC greenrig Waste Systems, Tanks & Totes 7 06-07-2009 06:14 AM
Toilet->Black holding tank connection mendosoft All Argosy Trailers 5 10-07-2008 06:48 PM
toilet not holding water The Oats Sinks, Showers & Toilets 23 07-24-2008 07:31 AM
Toilet not holding water for #2 Aluminumb Waste Systems, Tanks & Totes 9 12-14-2007 11:26 AM
