Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 05-30-2016, 08:10 PM   #1
Caffeinated's Avatar
2015 27' Flying Cloud
Newberg , Oregon
Toilet leaks around base intermittently.
So we had the Trailer out to the coast this weekend, and on a couple of occasions, found some water on the floor around the base of the toilet. It wasn't a lot of water, and it didn't appear immediately when we flushed the toilet, but would consistently reappear after a while. Anyone know what the cause, and fix might be?
Mike
2015 27 FC FB
Caffeinated is offline   Reply With Quote
Old 05-30-2016, 08:15 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Mike
2015 27 FC FB
Could it be condensation? Is yours a porcelain/China toilet? If so, depending on weather conditions, if you were/n't using AC, with Windows open, etc., there are lots of conditions for condensation.
But if it wasn't all over the pedestal, you may have a misfitting seal. Do the 2 bolts appear evenly tight? Is the bottom of the toilet touching the floor all the way around?
Old 05-30-2016, 11:59 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Put some food coloring in the bowl, then flush and see if leak matches it....I used this trick last week to determine my toilet had a leaking base seal.
CRH is offline   Reply With Quote
Old 05-31-2016, 11:08 AM   #4
Newberg , Oregon
I don't think it was condensation. I will have to check the bolts. The food dye is a good idea.
Mike
Old 05-31-2016, 12:10 PM   #5
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
This could also be slosh from the water in the bowl while towing. It has happened to us while on the road and we went up or down a steep entryway to a parking lot.
Of course if it happened while sitting still then ignore that and look at foot valve mechanism and the base seal for cracks or leaks.
Hope this helps.
ShinyPete is offline   Reply With Quote
Old 05-31-2016, 01:15 PM   #6
PKI
PKI's Avatar
Walnut Creek , California
Condensation
Splash from bowel
Cracked pex fitting at back on flush line
We had a puddle to left of toilet - no source was evident - believed condensation.
Rear plumbing and black tank destroyed - repaired and found a pex fitting leak - replaced - have not seen water since - check for a cracked fitting - believe variable water pressure may be the reason the leak comes and goes, but in time it likely will get worse.
May be condensation as we are in a dry climate and were not when we first saw the problem.
Powder on floor or paper towels taped around area may help you trace the source.
Good luck with investigation. Pat
Old 05-31-2016, 02:01 PM   #7
Rich W's Avatar
I'm In , Kentucky
Ours did that too, turned out the water line in the back of the toilet would occasionally drip and gravity just put it alongside the base of the toilet. I turned the fitting a little tighter and it's been ok for this past trip.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 05-31-2016, 02:14 PM   #8
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
of course if the roof vent is open and it's rainy and windy.... and you think EEWH who did that on my nice floor, then you realize it was you...
On the Avion I had a fantastic fan put in the bathroom - greatest thing in the world - condensation from shower GONE in six seconds. Evidence of chili dinner? What? it smells like rosebuds in here.
Leaky line happened to me, simple zero money fix.
Old 05-31-2016, 08:53 PM   #9
Newberg , Oregon
OK, it might have been condensation. It might be the seal at the base. Or maybe a pex fitting. Woo Hoo, this is fun. :/
Mike
Old 06-01-2016, 10:27 AM   #10
2015 25' FB International
North Kingstown , Rhode Island
Our first trip in our new 25 we had same problem.
It was the "O" gasket that seats the toilet to the floor. When we looked into the bowel with the valve opened you could see the ring across the opening , out of place. The toilet was bolted down tightly across the gasket... "Factory installed!"
Easy fix by lifting the bowel and resetting the gasket.
Good idea with the food coloring.
Bldog is offline   Reply With Quote
Old 06-01-2016, 11:25 AM   #11
2016 23' Flying Cloud
Corpus Christi , Texas
Toilet leak
Had same problem with new 2016 Flying Cloud. Back to dealer (under warranty) leak at conceptions.
2fromtexas is offline   Reply With Quote
Old 06-01-2016, 11:31 AM   #12
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Mine was dripping on the outside. I will try that food dye, that is a good idea. It will determine whether it is condensation or not.
cazual6 is offline   Reply With Quote
Old 06-01-2016, 05:14 PM   #13
lindaebrewer's Avatar
2015 23' FB Flying Cloud
Sacramento , California
Recognize the symptoms exactly. New foot valve kit for us. Thank you, Vinnie.
“The ability to think for one's self depends upon one's mastery of the language.” - Joan Didion
lindaebrewer is offline   Reply With Quote
Old 06-01-2016, 05:35 PM   #14
blackdog06
Blackdog06's Avatar
2017 25' Flying Cloud
2015 23' Flying Cloud
Tuttle , Oklahoma
Our toilet leaks once every trip a bit of water at the back of the base. I was thinking it might be from too much pressure as it seems to be by the shut off valve? Weird though, that it only happens one time and the rest of the trip is bone dry...
Blackdog06 is offline   Reply With Quote
Old 06-01-2016, 08:35 PM   #15
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I had this happen and found it was the handheld sprayers valve was sticking intermittently and leaking on the floor.
Old 06-01-2016, 10:29 PM   #16
Stay CazuaL
cazual6's Avatar
Reseda , California
Mine is not every trip. When it happens, it only happens at the beginning and then nothing after.
Old 08-14-2016, 12:45 PM   #17
Duck Alum(inum)
kevinmlamb's Avatar
2008 19' International
Eugene , Oregon
Installing the new foot valve
I think I have the exact same problem, a minor drip directly underneath the foot valve. I've seen a water droplet coming off the bottom of that black valve cover (or whatever it is; see photo; leak not included) under the foot valve. Did you install your own new foot valve? Is there a video or a website that will show me how to do this? Or is that something best left to the professionals?
kevinmlamb is offline   Reply With Quote
Old 09-03-2016, 10:55 PM   #18
Newberg , Oregon
I forgot about this old thread. For what it's worth, I resolved my issue by hand tightening the plastic compression nut by the toilet shut off valve. It hasn't leaked since.
Mike
Old 12-05-2016, 11:28 AM   #19
Gold Canyon , Arizona
2005 Safari LS 25'
So am a newbie and experienced the same problem while dry camping a few weeks ago. Note the trip was out for a total of 8 days, first four were dry camping, last four we had water and electric hooks ups. Same CG, different sites.
The water pooled on the left side of the toilet but was DEFINITELY leaking from either the flush valve or hose that connected the valve to the shut off. Could not figure out a patter when and why it would happen. I tried to tighten valve/hose connection but had difficulty getting pliars onto the fitting due to the proximity of the wall to the back of the toilet.
Suggestions would be welcomed!
Regards, Ed
ewhitney45 is offline   Reply With Quote
Old 12-05-2016, 11:40 AM   #20
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
Toilet is very easy pull to get at the valves and hose connections. The valves are pretty cheap so if I was pulling toilet I'd go ahead and get a new valve. When you install new valve make sure and use Teflon seal tape on the threaded hose connections. I do cold weather camp so I keep a spare flush valve in my tool bag.
1973Argosy is offline   Reply With Quote
1964 12 volt interior sconce lights shut off intermittently PA BAMBI II Lights - Interior & Exterior 4 05-26-2016 05:41 PM
Furnace goes off intermittently? LI Pets Furnaces, Heaters, Fireplaces & Air Conditioning 6 01-30-2010 04:17 AM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
