Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 03-25-2017, 05:35 PM   #21
2007 19' Bambi
Henderson , Nevada
Originally Posted by kevinmlamb View Post
I think I have the exact same problem, a minor drip directly underneath the foot valve. I've seen a water droplet coming off the bottom of that black valve cover (or whatever it is; see photo; leak not included) under the foot valve. Did you install your own new foot valve? Is there a video or a website that will show me how to do this? Or is that something best left to the professionals?
I have a drip at the same spot, off the black cover. What did you do to resolve your leak? Was it a DIY?
rmax1 is offline   Reply With Quote
1964 12 volt interior sconce lights shut off intermittently PA BAMBI II Lights - Interior & Exterior 4 05-26-2016 05:41 PM
Furnace goes off intermittently? LI Pets Furnaces, Heaters, Fireplaces & Air Conditioning 6 01-30-2010 04:17 AM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
