Old 05-27-2014, 01:20 PM   #1
Prior Lake , Minnesota
Toilet Leaking!
The toilet in the 1976 Streamline will flush - but then it leaves a puddle of water on the floor. Has anyone had this occur?
What may be the source of the leak? How would I fix it?
Any HELP would be greatly appreciated!!
Thanks!!
Wanda
WandaW is offline   Reply With Quote
Old 05-27-2014, 01:55 PM   #2
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
It's clear water, right? The pedal/ lever/ whatever actuates the flush opens a valve that is located within the toilet base. It's leaking when open- will need to be replaced or possibly rebuilt. To find it, follow the water line - it will connect to the valve. Often, you need to remove the toilet to get to the valve.
robert claus is offline   Reply With Quote
Old 05-27-2014, 03:02 PM   #3
Ottawa , ON
Lots of models listed here, most seem to have parts lists...
Old 05-27-2014, 03:07 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Thanks!!
Wanda
Hi Wanda
Quite a community of Airstreamers and Vintage trailer enthusiasts around Minnesota
Typically toilets leak during flushing as a result of frost damage to the water valve and related components. It can be remarkably hard to get all the water out of these in the fall before putting the rig away for the winter. Compressed air alone isn't always sufficient, may have to disassemble or use antifreeze.
Anyway you'll have to figure out what model of toilet you have and then see if the valve can be replaced, or, it may make more sense to replace the whole toilet especially if it has other problems.
toilet leaking at base Orson Waste Systems, Tanks & Totes 1 04-23-2014 11:12 AM
Toilet leaking... Skater Sinks, Showers & Toilets 10 04-19-2014 08:19 AM
Leaking toilet Bmtt Sinks, Showers & Toilets 6 05-10-2011 12:09 AM
Toilet Leaking... Need Suggestions samaki Sinks, Showers & Toilets 1 05-14-2010 07:32 PM
leaking toilet jgump Sinks, Showers & Toilets 5 06-02-2008 09:17 PM
