Old 03-27-2005, 01:30 PM   #1
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Toilet in 65 Caravel
I have the original toilet in our 65 Caravel. It has a copper pipe that goes from the bottum of the unit to the bottum of the fill tank on the back. The PO drilled this pipe at the bottum of the pipe in the U - why I dont know. I want to replace this pipe, but every time I go to make a replacement copper pipe, I end up creasing it...I can't get it rounded like the piece there. Any ideas? Will a new replacement toilet bolt right in? Any ideas, or has anyone had this pipe out and replaced it?
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 03-27-2005, 01:51 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Rob
Rob,
What size is the pipe? If it is small 1/2" or so, they make different grades of copper you will need one of the soft tubing grades to make the bend, IIRC it is
K but don't quote me on that
Aaron
WBCCI #XXXX AIR #2495
Old 03-27-2005, 01:57 PM   #3
robandzoe's Avatar
Plymouth , New York
1/2 Inch
Yes, I think it is 1/2. Yes, I've bought the maleable copper, but can't get the bend. I'm taking it tomorrow during lunch to a copper tubing shop here at home in NY. I'm not sure if the toilet is worth the trouble. We'll see.
Rob
Plymouth, NY 13832
Courtesy parking
Old 03-27-2005, 02:11 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
rob
you can get one of those spring benders for your project.
it looks like an oversized screen door spring with a funnel on one end.
you simply slide the tubing inside of it and make your bend. then it slides right off! they are available at most hardware stores.
john
you call them ferrets, i call them weasels.
caravel
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 06:46 AM
another Caravel owner davidw 1966-68 Caravel 46 02-03-2005 06:53 PM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
