Old 05-05-2011, 09:16 AM   #1
1960 24' Tradewind
Golden Valley , Minnesota
Toilet height- too high?
I'm trying to find a toilet for our 1970 Globetrotter with the rear corner wet bath. The PO installed a new Thetford Aqua Magic toilet but the problem is the height. The seating height is around 22" which is too high for me at 5'9" let alone my wife and six year old boy.
The shortest "low profile" toilet I can find online is 13" before it's mounted on the Globetrotter raised fiberglass base (can't modify it) which is about 8 or 9 inches- hence 21 -22 " height.
I believe a typical toilet seat height is around 16".
Any and all ideas/leads would be appreciated.
Thanks in advance- Sal
SalandViv is offline   Reply With Quote
Old 05-05-2011, 09:52 AM   #2
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
Could you do something like this? I did mine to move the bowl about 4 inches to the side withe a angle adapter. but you could do something simular and make the step stick out a little further than mine does. this method could be used if you are too tall for the potty also.[IMG]file:///C:/Users/175594/Desktop/picture_[IMG]file:///C:/Users/175594/Desktop/picture_034_thumb.jpg[/IMG]034_thumb.jpg[/IMG]
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 05-05-2011, 11:12 AM   #3
1960 24' Tradewind
Thanks but my wet bath is a lot more limiting and really no option for moving things around to help. I could always come up with a removable step/platform but I'd like to have a more elegant solution than that.
I'm amazed that no one makes a shorter toilet- what do the new wet bath Airstreams use?
-Sal
Old 05-05-2011, 11:24 AM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
The thetford I just took out of MH is 11 inches without the adapter base of 3 inches.
The new one I put in was 14 inches without the adapter base.
So you would have 19 inches even with this lowest they make on your pedestal.
Old 05-05-2011, 12:29 PM   #5
1960 24' Tradewind
The base or floor rise is about 8" under the toilet so I would end up at 22" which is the problem at hand... I'm starting to think I need to find an old toilet that can be refurbished? I had a 1973 Tradewind that had a similar rise and the toilet didn't seem too high...
Old 05-08-2011, 11:06 AM   #6
1960 24' Tradewind
thanks DaveFL...
Thank for your help- hopefully I've got this one solved and it's on to the next one.
-Sal
Toilet mounting flange Green68 Sinks, Showers & Toilets 7 03-21-2011 08:21 PM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
Ball height measurement from 200 miles away Section8 Hitches, Couplers & Balls 8 01-20-2011 08:12 PM
How and When to Measure Hitch Height lcurrie Hitches, Couplers & Balls 9 12-30-2010 01:59 PM
