Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 08-06-2004, 04:44 PM   #1
Armorhotdog
Profile:  Oregon City , Oregon
Toilet flapper loses standing water
To my surpise on this trip. I noticed no standing water in the bowl. I have let the lever spring back hard to get a fast close, pulled the lever up with my foot to 'seal' the hole....
Any tricks? Can't imagine that it decided to fail today after 40 yrs. Grrrr
Armorhotdog is offline   Reply With Quote
Old 08-07-2004, 10:16 AM   #2
nickcrowhurst
Profile:
First try a little quality time with your head down the bowl. In your hand you will need a toothpick or matchstick. (Wear rubber gloves). Close off the water valve behind the bowl. (not essential). Open the closing device using the foot pedal, and jam the pedal down with a piece of wood between the pedal and the body of the bowl. (I use a folded Leatherman tool in its leather case. It's just the right size, and a little resilient.) Use the toothpick to clean out the groove into which the closing plate normally fits. A small mirror helps to see into the groove. If you are lucky, you will find a screwed up piece of toilet paper within the groove. Once this is removed, the bowl should hold water. (Remember to turn on the water valve) If this process fails to fix the leak, then you can remove and dismantle the toilet, and use a repair pack to replace the rubber gasket. In my experience, the whole mechanism under the bowl will be rusted, and a replacement modern WC will be a sound investment. You can spend a lot of money and time on replacing parts, and the WC will still be inefficient. Been there, done that, unfortunately! Good luck. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 08-15-2004, 01:50 PM   #3
Armorhotdog
Thanks! I will dig out the snorkel this weekend. Glenn
Old 05-09-2006, 06:11 PM   #4
cowcreek7
Profile:  2006 28' International CCD
Pecos , New Mexico
My toilet had the same problem. Airstream of Spokane told me to spray the seal and ball with silicon spray and that would fix it. IT DID!
cowcreek7 is offline   Reply With Quote
Old 05-09-2006, 07:50 PM   #5
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Be CAREFUL with that silicone spray!!! Be certain that it contains only pure silicone and no petroleum distillates in the mix or as propellants as they will do far more damage than good .
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 05-09-2006, 09:17 PM   #6
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I had the same problem with my old toilet. I tried all the above tips, but to no avail. I bit the bullet and bought a new pot.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 05-09-2006, 09:47 PM   #7
ArtStream
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
Talking to God
If the above does not work, Tetford makes a rebuild kit.
A couple seals, some bleach solution and rubber gloves, walla she's as good as new!
Michael
Click here
Holiday Gifts Just for Airstreamers
FREE EXPRESS SHIPPING
8892**VAC**KC2TQU
ArtStream is offline   Reply With Quote
Old 05-10-2006, 06:25 AM   #8
steelbird312
steelbird312's Avatar
Profile:  1989 29' Excella
Griffin , Georgia
Images: 11
Woah!
Hold on, with the toothpick. If your hands are big, or crippled with some arther, or if you just don't wanna get your hands dirty, buy a cheap screwdriver with a long, thin shank. Take a hacksaw, cut off the head so it looks like a stiff steel rod or wire with a handle. Use a file or sandpaper to clean off any burrs from the cut. Next, using vice grips, a vice, etc, bend the last inch 90 degrees. You now have a tool you can keep in your unit at all times that you can make real quick work of removing compacted toilet paper from the sliding gate groove WITHOUT getting your hands in it.
I have, in a pinch, made a tool out of a very stiff cloths hanger. Just be sure to clean off all burrs.
Now, WARNING!!!!!!!!!!!! DO NOT SCRATCH THE INSIDE OF THE PLASTIC GROOVE AS IT WILL FOREVER SEEP THE WATER OUT!
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 05-10-2006, 09:37 AM   #9
Cracker
Cracker's Avatar
Profile:  2000 30' Excella
Pittsfield , Maine
Go replacement!
I agree with Pick! The PO of my unit had used some kind of "toilet cleaner" and left the residue in the bowl. That virtually corroded the seal plate - and no amount of tinkering could fix it. We bought a new Thetford porcelain bowl toilet and commited the old unit to the dump.
Cracker
Cracker is offline   Reply With Quote
toilet water line leak mlmarch Fresh Water Systems 0 07-27-2004 09:46 PM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 06:37 PM
Standing water in drains hhuber Our Community 11 07-30-2003 08:20 AM
No water to toilet Oak Sinks, Showers & Toilets 13 11-01-2002 07:31 AM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 11:03 AM
