I need to replace the toilet flange in my 1972 Sovereign. The outer ring of the flange is damaged and won't permit bolting down the toilet.
Does anybody have any advice on getting this blasted thing out? The outer ring freely turns but I can't get at the main part of the metal flange in the middle that screws into the blank tank.
Does anybody have any experience working on these? Is there a special tool?
__________________ 2003 Ford Excursion (6.0L PSD) Prodigy / Equal-i-zer / Honda EU2000i / Xantrex Link 10 U.S. Navy (Retired) Airstream Life Contributor Air#5661 / WBCCI#--
I made this one with my wire feed welder to remove the flange in my tank. This very tool removed the stuck flange on VINTAGE THUNDER in less than 30 seconds! I wonder if that will increase it's value if I decide to sell it on Ebay. Hmmmm.
1972 27' Overlander 72 Overlander Jack Pad--- A notebook used by Jack Nicholson in the Shining to keep track of how much work he had done on his Airstream. "All work and no polishing makes Jack's Airstream a dull trailer"
I used a hammer, and a thin bladed chisel, to unscrew the flange. It was a pain in the @!@#$.
Unscrewing is counterclockwise, just like a bolt.
I just removed mine from the '73 Sovereign and I used a hammer and screwdriver. There are two slots opposite each other and you need to patiently work it out. It took a while because it was threaded in quite a ways. Be careful as you don't want to damage the tank
(Tripoli sailors were always just a bit ahead of New Orleans.)
If the flange was one piece there would be little problem getting it out. But my flange essentially has two pieces: the center piece which screws into the black tank and an outer ring which spins freely with the small screws removed.
...The outer ring freely turns but I can't get at the main part of the metal flange in the middle that screws into the blank tank...
Mike,
FWIW, on my Overlander, the outer ring was metal, but the inner part was ABS plastic. Circled in one of the pictures below are the recesses Sneakinup's masterful creation was designed to accomodate. I'm fairly sure that was where Ron & Terry were also gently persuading the flange to unscrew.
You may not have an original flange. If yours has no recesses, you may want to consider cutting the outer ring off, and using a rather large pipe wrench to unscrew the inner part. A new, one piece flange will be available from any RV dealer for under $10.
Tom
Tom, those are the notches I chiseled into to get mine off. It had been on there for 30+ years, and resisted mightily, but resistance is futile.
Resistance IS futile. Thanks everyone for the tips. I ended up using a rubber mallet and flat bladed screwdriver. Only took about 15 minutes.
