Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 05-20-2007, 01:20 PM   #1
ayresdream
ayresdream's Avatar
Profile:  1971 29' Ambassador
Merritt , British Columbia
Toilet Flange Thread in '71 Ambassador
Before I get going on doing some work on the bathroom, I want to have everything I need in advance... Does anyone know what type of flange I need for the toilet? Will it be male or female threaded? Do I need to get it from an RV store, or will a hardware store have one?
Donald
ayresdream is offline   Reply With Quote
Old 05-20-2007, 03:23 PM   #2
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
What brand and model toilet do you have. By flange are you talking about the flange seal.
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 05-20-2007, 05:05 PM   #3
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
I'm pretty sure you will need a toilet flange with 3" male threads. It will likely screw into the black tank.
You'll need to get it at an RV store I would think. They use a rubber seal not a wax ring so the flange has a nice groove for the seal.
You might want to pick up a new seal while your at it unless your putting in a new toilet which comes with one.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 05-20-2007, 05:51 PM   #4
ayresdream
ayresdream's Avatar
I figured since I was going to pull the toilet off I might as well replace the flange and gasket. I replaced the toilet four years ago, and remember the flange was looking pretty old.
I just wanted to make sure I had the right one to replace it with. I'll definitely use the foam gasket.
Donald
Old 05-20-2007, 06:12 PM   #5
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
Having solid plywood to tie mechanical anchor into was flaw in my 27', without wrecks or other factors considered I'm sure it helped crack the BW tank around the nylon weld allowing it to flex...
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Old 05-20-2007, 06:41 PM   #6
Safari Tim
Safari Tim's Avatar
Images: 35
For the screw on's you only have a male thread or female. They only cost about $4 each. Buy both to be sure!
-Tim
Old 05-21-2007, 12:02 AM   #7
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I recently installed a Sealand on my '72. The instructions had me install a universal flange kit. If we are talking about the same thing...
Dave
Fyrzowt is offline   Reply With Quote
Toilet chemicals gwsullivan Waste Systems, Tanks & Totes 33 02-24-2005 01:28 PM
Toilet dmac 2001 Safari 4 12-11-2002 08:29 PM
Toilet Paper: Is scotts ok? TBKP's Overlander Plumbing - Systems & Fixtures 11 11-29-2002 09:03 PM
Opps... (Split thread problem) Andy R Our Community 1 10-19-2002 03:12 AM
Toilet valve problem Charles Q Treichel Sinks, Showers & Toilets 1 09-04-2002 11:59 AM
