04-13-2009, 05:34 PM
1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Brussels
, Wisconsin
Toilet Flange on the 88
I am replacing the toilet in my 88 from the old plastic to a new Sealand. The problem is the flange holes are set so that they don't line up with the new Sealand, they are at a weird angle and not square across the floor line. If you would install the new Sealand with the current placement of the flange the toilet would be turned towards the door and not face straight towards the shower. I have tried to move the flange but it will not budge. Is this screwed into the tank, glued or just sitting there and I need to more a-- behind it to move it? Is there a way to adjust the flange so that I can get the screws to line up or an adaptor to get?
Thanks in advance for telling me what I should know!!!
I'm NOT an old man.............
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
04-13-2009, 08:37 PM
1968 30' Sovereign
1959 18' "Footer"
Brussels
, Wisconsin
Add a Flange
Can I add another flange and it still work?
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
04-13-2009, 10:03 PM
1977 Argosy Minuet 6.0 Metre
Cape Coral
As you look down on the flange, does it appear to be one solid piece or does it have an inner and outer flange separated by a seam? If it is a two piece, the outer part should rotate and allow you to move the slots to align the potty. Perhaps it is held down by a screw or two or is just tight. The inner part of the flange or the whole flange (if it is a one piece) is likely screwed into the tank. You may see some small notches at the inside of the flange. A hammer and a punch may move it. You may have to fabricate a tool to grip and turn it. It should come off counter clockwise as you look down on it. It's highly unlikely that it is glued.
When I installed my new sealand, I had to unscrew the flange, add 2 additional notches to accomodate the 4 bolts, then screw the flange back on and align the notches. The rubber gasket that comes with the sealand is all you need for a good seal. It took patience and bravery for me to get the flange off, but it did screw off. Good luck.
flcracker
04-14-2009, 04:58 AM
2006 30' Classic S/O
Mohrsville
, Pennsylvania
Ed,
We have an '87 and the closet flange was the threaded type. All I had to do was remove a couple of countersunk wood screws from the flang and unscrew it. It took a little leverage to get it unscrewed. You can read about how I made a spanner wrench from a scrap piece of 2 X 4 and the key bolts that hold the toilet to the closet flange here in post #35...
http://www.airforums.com/forums/f461...ter-41785.html
Like Archimedes said..."Give me a lever long enough and a fulcrum on which to place it, and I shall move the world."
PS - I determined that ours was threaded by cleaning the tank REALLY well, donning a pair of surgical gloves, and I could feel the threads on the closet flange as it extended past the tank opening on the inside.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
04-14-2009, 11:17 AM
1968 30' Sovereign
1959 18' "Footer"
Brussels
, Wisconsin
Going to give it a try
I just went out at lunch and picked up some new key bolts to use as part of the spanner wrench, so if they bend I still have the new ones that go with the new toilet. I will give this a try tonight and report back.
Thanks for all the info!
Ed
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
04-14-2009, 11:24 AM
Mohrsville
, Pennsylvania
Ed
Ed,
Be sure to give the underside a feel to make sure you have the threaded closet flange. I would hate to see you apply leverage only to have you discover that you have a flange that was glued / cemented into the black tank and break the flange, the tank, or both.
Take a look at this thread too...
http://www.airforums.com/forums/f444...nge-45782.html
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
04-14-2009, 11:26 AM
1986 31' Sovereign
Miami
On my 86 I just rotated the whole flange counter clockwise the same way as post#4 until the key bolt slots lined up for the Sealand. Totally painless.
mike
04-14-2009, 12:45 PM
1968 30' Sovereign
1959 18' "Footer"
Brussels
, Wisconsin
Easy??
mike
Did it turn easy? I have tried to tap it with a hammer to get it to move but it did not. I have removed the wood screws that go through the flange to the floor.
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
04-14-2009, 12:53 PM
Mohrsville
, Pennsylvania
Ed,
I whacked mine with a hammer and it would not budge, but once I applied the homemade spanner wrench it came out very easily.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
04-14-2009, 01:01 PM
1986 31' Sovereign
Miami
I put the two key bolts in place and then used a 3' length of scrap 1x1 to turn the flange by wedging it between the two bolts to use as a lever. It was stiff but it did turn (slowly).
I would not whack it with anything -- a steady strain is mo' better
mike
04-14-2009, 07:45 PM
1968 30' Sovereign
1959 18' "Footer"
Brussels
, Wisconsin
Its In!!!!!
n2916s, DEITZ645, georgezink you guys rock!
I was able to use the info you guys provided and was able to move the flange enough to seat the new toilet.
God I love this list!!!!!
Thanks guys, I now can follow life rule number 5, "Life is too short to poop in a dirty potty."
Ed
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
04-14-2009, 07:47 PM
1968 30' Sovereign
1959 18' "Footer"
Brussels
, Wisconsin
Yes!!!
mike
Painless is the word of the day!
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
04-14-2009, 07:49 PM
1968 30' Sovereign
1959 18' "Footer"
Brussels
, Wisconsin
yuck
Originally Posted by DEITZ645
Gloved hands I feel around, can't tell so the gloves come off and the raw finger in the tank tell me there are threads there.
Time to move the flange.
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
04-14-2009, 07:51 PM
1968 30' Sovereign
1959 18' "Footer"
Brussels
, Wisconsin
One!
Originally Posted by georgezink
As you look down on the flange, does it appear to be one solid piece or does it have an inner and outer flange separated by a seam? I Good luck.
When I saw no seam I knew I was in luck.
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
04-15-2009, 05:15 AM
Mohrsville
, Pennsylvania
Ed,
Which hand did you use? Please don't be offended if we ever meet and I don't shake your hand.
I'm glad to see you got the throne installed correctly.
PS - How come you don't have the '88 listed in your profile?
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
04-15-2009, 05:46 AM
1968 30' Sovereign
1959 18' "Footer"
Brussels
, Wisconsin
88 not listed because I can only list 3 I think and the 88 is #4
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
04-15-2009, 05:53 AM
Mohrsville
, Pennsylvania
Ed,
How did you talk your wife into Airstream #4??? I am finding it impossible to persuade mine that a third one (small vintage coach) would be a good idea .
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
04-15-2009, 03:49 PM
1968 30' Sovereign
1959 18' "Footer"
Brussels
, Wisconsin
Lefty
Ed,
As always it is the left hand that I use, so we should be OK with a handshake!
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
04-15-2009, 03:51 PM
1968 30' Sovereign
1959 18' "Footer"
Brussels
, Wisconsin
Persuade??
Ed,
Heck she's the one that finds them!!!!!! She's worse than me, she will say "we can find room"!
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
