02-21-2015, 08:52 AM
"Tinbad ... the Trailer"
1965 26' Overlander
Ferndale
Toilet brush down the hole!
I just knew this was going to happen some day....drat.
Worst part is I can see it but not manage to grab it....
Actually that's not the worst part....I've had trailer guests
over for 4 days and it's time to dump.
Yuck....I think I'm going to have to remove the toilet as I don't
want the brush getting stuck in the Thetford valve.
Any suggestions??
02-21-2015, 08:55 AM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Maybe a long-handled grabber thing? You know, like the ones folks use to grab a can off a high shelf, or something off the floor.
02-21-2015, 09:01 AM
Or even a coat hanger, bent into a hook
02-21-2015, 09:04 AM
1964 22' Safari
modesto
Go fishing!
02-21-2015, 09:21 AM
Oswego
-Rich-
02-21-2015, 09:23 AM
Green Cove Springs
The claw, the claw!
02-21-2015, 09:25 AM
1965 26' Overlander
Ferndale
Turned off the water and shone a light down there, I think it floated off somewhere...it's no longer in view which is more than I can say for....never mind.
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Go fishing - but first get two heavy plastic trash bags one inside the other - and get some vaseline which you should apply heavily to your upper lip (you'll thank me for that one!) Rubber gloves wouldn't be amiss either. So grab it with a hanger, or grabber or whatever it takes - yank it up to a point where you can grab it, bag it, seal it and take it far far away for disposal.
Then you can wipe off the vaseline.
Paula
02-21-2015, 09:27 AM
2002 31' Classic
Monroe
, Iowa
Been there, done that.
In my case I was camped in Wyoming with a group of Antelope hunters. It took two of us to get the darned thing out.
I straightened two wire coat hangers. One, I left the rounded hook end as it was. The other one was completely straightened, except for the curly place where it joined together below the hook, and bent a small srraight hook about 100 degrees, about an inch and a half long.
One of the guys took the wire with the round hangar end and lifted the brush handle to where I could get the little straight hook thru the hole in the handle, then gently pulled the brush out.
Oh yeah, it took several tries before we finally got it.
02-21-2015, 09:50 AM
1965 26' Overlander
Ferndale
Got a role of bailing wire and going to "go fishing".
02-21-2015, 10:01 AM
2005 19' Safari
GLENDALE
, AZ
Sounds like a good idea for a new, RV-themed, "Survivor"-type reality show entitled "Toilet Brush Down the Hole!"; or a "Duck Dynasty" episode where the good ol' boys design and market gear for the new sport they invented called "RV commode fishing", which is similar to noodling for catfish, but actually more like a treasure hunt for @#$%...
By the way, glad you got the toilet brush out!
(Oops, missed your previous post while typing.)
HOPE you get the toilet brush out!
02-21-2015, 10:15 AM
1965 26' Overlander
Ferndale
could not fish it as I've no idea where in the tank it is. Turned off the water and tried a mirror and flash light...too tight to get the correct angle.
So I filled to absolute capacity with fresh water and let'r rip out to the septic field.
When empty I removed the see through stinky slinky outlet and note a right angle
that would not allow for the passage of the toilet brush.
So back flushed with a full grey tank and am now filling Black tank with fresh water.
When it is nearly full I'll get a garden hose down the 'bog" at such an angle that it might create a current that "might" bring it into view.
Barring all that I've been meaning to drop both tanks (already did the F.W. which is a pain in it'self )and clean and re-insulate. But until then it's going to have to stay as I'm at a critical phase of.....see pic....I got the weather going for me and I need to button up the "Hay Wagon" but at least the floor is all in as of today....
02-21-2015, 10:53 AM
2015 25' FB Flying Cloud
Georgetown
After reading these comments I think I'm going to drill a small hole at the top of the toilet brush handle and tie three or four feet of twine to it. I'll let the twine trail behind the brush while I'm using it (or tie it around my wrist like a surfboarder), and if the brush slips down the hole hopefully I can drag it back up.
02-21-2015, 10:55 AM
2002 30' Classic S/O
Garden Valley
, Idaho
I'll bet your wife has small hands and if you hold on to her feet, she can get down there and grab it.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
02-21-2015, 11:03 AM
Dallas Center/Des Moines
, Iowa
Pulling the toilet should end the madness.
02-21-2015, 11:30 AM
2004 30' Classic Slideout
Fenton
, Missouri
Here's a link back to my 2007 post about a foreign item going into the toilet... http://www.airforums.com/forums/f239...tml#post469119
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
02-21-2015, 11:45 AM
Virginia Beach
, Virginia
I have withheld this story for five years, but here goes.
A neighbor of mine is a chronic practical joker - his long suffering wife just responds by buying more and more life insurance so that when she has him bumped off, it will pay her well!
So... finally he pulled a tasteless prank that was just the last straw. She vowed revenge and got a rubber tarantula that was spring loaded so that it could jump off of the table or whatever. He and a buddy were watching the Redskins go down the crapper when her hubby decided to clear the way for a few more brewsky's and stepped into the unlighted bathroom. He turned the light on, raised the lid and was just getting ready to sprinkle when he saw the spider - and tried to flush it down - whereupon the spring let go, the spider flew up and he, in shock screamed like a girl and baptized most of the bathroom walls, floor and ceiling!
Talk about a practical joke backfiring.
Neither of them will EVER live that one down.
Paula
02-21-2015, 11:52 AM
2012 23' FB Flying Cloud
Santa Rosa Beach
I agree that you should just be done with this and pull the toilet from the floor. I did that job last year on Old Lucy (2000 Safari 25FB) in order to replace the flapper gasket. I replaced the floor gasket at the same time. I would recommend that if you do pull the toilet, you replace both of these gaskets.
Once the toilet is out, I think that you will have much better shot at retrieving the toilet brush. I would try this first as pulling the toilet is pretty easy compared to pulling the black tank.
Your dilemma has taught me a lesson. I am now shopping for a toilet brush with a 3' handle.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
02-21-2015, 01:27 PM
woodhaven
, New York
Foiled again... take off the Vaseline AFTER you take off the gloves. Lol
02-21-2015, 01:33 PM
2012 27' Flying Cloud
W
, New England
Is the Vaseline for smell? If so, wouldn't something like Vicks Vapo Rub be better to mask things?
I have a goatee and mustache - never stuck Vaseline on my face before - sorry if this is a dumb question.
And good luck with the toilet!
