Old 12-01-2015, 06:03 PM   #1
2012 27' FB International
Boulder , Colorado
Toilet bowl very slowly leaking
No visible cracks in the stopper (like last time), have used pure silicone when winterizing so rubber seal isn't dried out. Any ideas what to look for? Last time Dometic just replaced it due to crack, so toilets a year old.
motozen is offline   Reply With Quote
Old 12-01-2015, 06:29 PM   #2
2015 30' FB FC Bunk
Ayer , Massachusetts
Does it have a ball that rolls into the seal?
I had that on my old trailer and always had one issue or another.
Once the band clamp was loose, it is like a big hose clamp at the base of the toilet.
Then twice there wast junk stuck around the seal where it met the ball.
Last time they replaced the valve with the ball.
Ted S. is offline   Reply With Quote
Old 12-01-2015, 06:31 PM   #3
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
The Dometic in my unit leaked a bit as well and I could not see any problem with a visual inspection of the bottom seal so I took the toilet off to have a look. Flange gasket appeared ok and the water intake valve did not appear to be leaking. Mine was assembled with a joint running horizontally about half way up the bowl and the whole contraption was a bit loose. The halves can be retightened with a screw driver. Access from the underside. Once retightened, all was good. Jim
Jim Flower is offline   Reply With Quote
Old 12-01-2015, 07:41 PM   #4
Boulder , Colorado
Yes, it has the rotating spherical stopper. I cleaned and inspected the rubber seal and it appears fine.
The bowl is one piece with no visible screws to tighten.
Old 12-02-2015, 11:34 AM   #5
1977 31' Sovereign
Lynnwood , Washington
Sounds like the seal's dried out. It's a routine maintenance sort of thing.
Did you grease the seal after you cleaned it??....with plumber's grease??
Tom
TomKirk is offline   Reply With Quote
Old 12-02-2015, 11:59 AM   #6
1986 31' Sovereign
Miami , Florida
Always helps to let it spring closed -- if you let your foot up gently on the pedal, it doesn't drive the edge of the ball as far into the gasket. Works on mine, anyway.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 12-02-2015, 12:54 PM   #7
2007 25' Classic
Hutto , Texas
Mine occasionally lets the water seep out. Usually after we haven't used it for a few weeks and it's dried out. Put a tablespoon of olive oil in the dry toilet bowl and let it stand for a day. The oil will lube the seal and will help. I've fixed ours several times by doing this.
Wanderer2604 is offline   Reply With Quote
Old 12-02-2015, 01:33 PM   #8
Hard to believe the seal is dried out in one year, especially given you've used silicone, cleaned it and checked for defects. But, it happens. I had the same symptoms without indicators. Followed the toilet OM troubleshooting guide, which said, as the 2nd to last resort, remove/replace the rubber seal. The last resort was to replace the toilet. But, you've already done that. I ordered the seal online, as my local rv guy had some, but not for Dometic brand, and couldn't/wouldn't guarantee a correct fit. Replaced the sealwhen it came in the mail and it hasn't leaked a drop since...or should I say "yet"?
Rokitman is offline   Reply With Quote
Old 12-02-2015, 07:09 PM   #9
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I find RV antifreeze works pretty well on rubber seals. I had a new dump valve seal get sticky when I pulled the valve open. I sprayed RV antifreeze in there and it started working smoothly again. I keep an inch of RV antifreeze in my toilet bowl all winter.
David
Old 12-02-2015, 07:32 PM   #10
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I smear silicon grease around the seal every few months.
Make sure there isn't something small stuck in there breaking the seal.
Doug and Cheryl
Old 12-02-2015, 10:07 PM   #11
Boulder , Colorado
Thanks for all the replies guys. I put on some nitrile gloves, folded a paper towel, and thoroughly cleaned the entire gasket and the spherical stopper, then I cleaned the sealing edge with the stopper closed....so far so good. I'm not convinced yet, but we'll see in a few days. When faced with a problem, it helps to know you are not alone...this forum is awesome!
Fork down toilet bowl Bert Gildart Plumbing - Systems & Fixtures 34 01-16-2013 04:47 PM
Toilet-Aqua Majic 30 leaks water into bowl 2coldnpagosa Sinks, Showers & Toilets 4 09-10-2010 08:47 PM
Plastic toilet bowl cleaner wacnstac Sinks, Showers & Toilets 4 07-05-2006 05:00 PM
sideways toilet bowl? lesliedow Sinks, Showers & Toilets 3 08-22-2005 09:28 AM
Toilet Bowl Seal Question? JoeW Sinks, Showers & Toilets 1 10-09-2003 10:34 PM
