Old 10-09-2003, 10:05 PM   #1
Toilet Bowl Seal Question?
Toilet on my 87 29ft Sovereign will not hold water after filling and it leaks back into black water tank. I suppose there is a seal I can buy? Any help appreciated.--------------JoeW
JoeW is offline   Reply With Quote
Old 10-09-2003, 10:34 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Yep.
You're looking for the slide seal or something like that. You'll have to - er, I mean you'll "get to" take the toilet off to do it, and you should probably put on a new base seal for $4 or $5 while you're there.
You might also check how the vinyl hoses inside the toilet are doing while you're there.
The big trick is finding the rear bolt to get the toilet off. You'll find some threads here about it.
Remember what the toilet looks like, because if it's not the original one, there's umpty zillion different kinds.
Don't forget to wash your hands and clean under your fingernails when you get done...
-Don
Toilet changing tips... drboyd Sinks, Showers & Toilets 2 07-18-2006 01:28 PM
64 Swirlomatic toilet MW64OVERLANDER Sinks, Showers & Toilets 1 10-27-2003 09:57 PM
Toilet FireFighter Sinks, Showers & Toilets 7 08-06-2003 01:56 PM
remove/reinstalling the toilet Chuck Sinks, Showers & Toilets 7 07-28-2003 02:44 PM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 05:53 PM
