Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 12-16-2003, 08:13 PM   #1
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Toilet bolts
I am amidst flooring repair, and am desparately trying to remove the toilet bolts. It seems the studs are spinning with the nut firmly seized, even though i soaked them with a rust penetrant. I can't spin either nut off the studs, nor the studs out of the floor. Any ideas?
A search only reveald hard to get to bolts ( agree) and leaking ball valves etc.
Uwe
Old 12-16-2003, 08:23 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
The real question is are you going to try to reuse the toilet?
If not then a sawzall will make short work of the old bolts. If you are trying to save the toilet then you need to use a nut splitter, but I have no idea how you would fit it in the space available
How about a dremel or a drill with a thin cut off wheel?? Again space may be a limiting factor.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 12-16-2003, 08:33 PM   #3
Moonshot
The Painted Pig
Moonshot's Avatar
Profile:  1979 Argosy Minuet 7.3 Metre
East Central , Alabama
Images: 14
Sorry, Uwe. This won't help you, but others reading this thread might be interested to know that the PO of my Argosy (or Airstream factory?) had installed screws up against the toilet bolt heads to keep them from turning when the nuts were removed.
Another thing the PO did was not so nice. He apparently had a leak around the toilet flange. To fix this he glued the flange to the black tank. I broke my black tank trying to remove the flange.
I'd be rather upset except my black tank had serious cracks causing it to leak anyway. That's why I was removing it.
Now, if someone out there knows how to fix the cracks in a leaky plastic black tank... I'm not listening... hmmm....hmmmm...hmmmm
Scott
Moonshot is offline   Reply With Quote
Old 12-16-2003, 09:51 PM   #4
uwe
418
uwe's Avatar
Images: 40
I must be the luckiest guy alive. I rotated the tilet about 75degrees to the right, and it basically fell off the flange. This time rust was my friend.
Next issue: the flange that protrudes into the black tank. How this come off?
Now that I got lucky removing the toilet, i am afraid the flange will break, etc.etc.
The metal flange with the 6 screws basically deteriorated into powder. It looks like this once was underneath the black flange. I will be needing a new toilet and some hardware, at least.
Any help appreciated. Thanks for the replies so far.
Uwe
