Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 01-16-2012, 05:07 PM   #1
1965 22' Safari
Send a message via Skype™ to chromis
Toilet and Tank Vent pipe plcement
I have a problem with the location of my vent pipe and my toilet.
The vent pipe exits too close to the toilet and I'd like to get some knee room by moving it towards an adjoining wall.
The best I can think of is to cut the abs pipe, add elbows top/bottom, run it inside the adjoining wall, and case-in the exposed elbow at top/bottom.
Figuring not a huge deal as it is just an vent pipe..
Any recommendations/concerns/alternatives ?
chromis is offline   Reply With Quote
Old 01-16-2012, 06:10 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I rerouted the vent in our Argosy without a problem. If you are going behind what appears to be a wall in you drawing and then coming back thru at the top to the original vent location I would suggest using two 45 degree elbows at the top and bottom instead of two 90 degree elbows at each location.
Grey Water Tank Flushes Toilet (to conserve fresh water) LittleRadio Sinks, Showers & Toilets 10 11-14-2021 10:45 AM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Waste tank issues? 1969 Overlander edglenn Plumbing - Systems & Fixtures 4 10-04-2011 10:59 AM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 04:53 PM
mounting toilet flange on black tank 386kustoms Sinks, Showers & Toilets 3 03-04-2011 07:52 AM
