Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 08-06-2003, 09:56 AM   #1
FireFighter
FireFighter's Avatar
Profile:  Currently Looking...
bay city , Michigan
Toilet
I have a 1970 31' International Sovereign Land Yacht
the toilet has a black rubbery seal between it and the screw in flange on the top of the black water tank.
This seal is diminished to the point that it will not hold a seal and water is leaking onto the floor with each flush.
I need help either finding a replacement seal or finding a replacement toilet
Thanks.
FireFighter is offline   Reply With Quote
Old 08-06-2003, 11:08 AM   #2
Gunnyusmc
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
gasket
I got the gasket at my local RV dealer, but take the old one to the dealer with make and model of toilet, as there are several styles.
Gunnyusmc is offline   Reply With Quote
Old 08-06-2003, 11:15 AM   #3
Coloradobus
Profile:
toilets
We have the original toilet in our '67 Globetrotter. Setting it on the lawn, we ran a hose to fill the bowl with water. Letting it sit for a few minutes, the water level drops. Guess we have a bad seal, or is this a feature that drains the bowl automatically so water doesn't splash out while travelling?
Coloradobus is offline   Reply With Quote
Old 08-06-2003, 12:15 PM   #4
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Bus: that's a different seal than firefighter is referencing. He's talking about the one that is analagous to the wax ring seal on your house toilet. The one you're talking about seals the blade-valve that controlls flushing. My understanding is that it too can be replaced. You might try cleaning out the groove that the blade slides back and forth in with a coat hanger. Sometimes little pieces of TP can get jammed in there by the blade if you let it close too quickly. that'll make just enough room for a sloooow leak.
I've also read here that silicone spray on the valve seals will help to lubricate them.. And there's some stuff that thedford sells called "drain valve lubricant" that might also help, although I believe it is intended for the waste tank valves..they pretty much work the same way.
Old 08-06-2003, 01:26 PM   #5
FireFighter
bay city , Michigan
make and model
am i to assume that the model of the toilet dictates the seal rather than the model of the trailer?
Old 08-06-2003, 01:48 PM   #6
Chuck
Chuck's Avatar
Images: 99
yep. I don't think airstream had any proprietary toilets...but I could be wrong. pretty safe bet that they always used 3rd party standard stuff in that department.
I have a thedford in mine...don't know if its original or not.
Old 08-06-2003, 01:51 PM   #7
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
This may be what you are looking for....
This is a bottom end seal rebuild kit. Does not contain a new blade valve though, just the seals. I paid $26.95 from local RV place.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 08-06-2003, 01:56 PM   #8
FireFighter
bay city , Michigan
Thanks Pick that picture is exactly what i am looking for and it even has the part number showing.
this is the greatest web site on the net.
Toilet changing tips... drboyd Sinks, Showers & Toilets 2 07-18-2006 01:28 PM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
64 Swirlomatic toilet MW64OVERLANDER Sinks, Showers & Toilets 1 10-27-2003 09:57 PM
Toilet replacement pinebenny Sinks, Showers & Toilets 2 09-23-2003 11:52 AM
remove/reinstalling the toilet Chuck Sinks, Showers & Toilets 7 07-28-2003 02:44 PM
