Originally Posted by garry
On the top left under the seat there is a plug remove plug and a 7/16 or 1/2 nut way down at the floor you need a few extensions or one real long one.
Under the foot flush is another nut easer to get to.
These instructions are based on an Aqua Magic
Yes, if your toilet is the original Thetford you need to remove the plug at the top and with a swivel and extensions you can get at the bolt in the back. The one in the front you can find, as noted, under the front foot flush area. Once you take the nuts off, and the water line is disconnected, it will lift right off.
