Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 08-21-2006, 05:45 PM   #1
toastie
toastie's Avatar
Profile:  1965 17' Caravel
1955 22' Safari
Livingston County , Michigan
Time to retire the 65 Caravel Townsend toilet
The toilet works fine most of the time, but there is time I get a little water from the bottem flange, also the bowl fills with to much water some times, and being 41 years old it time to replace, I'm looking at the SeaLand Traveler 500 Plus, Airsteram did install a new black tank and supported the old toilet with some 3/4 " plywood, my question is, are they hard to install, and is Sealand a good product, I attached a few pic's....
ID:	25024   Click image for larger version
toastie is offline   Reply With Quote
Old 08-21-2006, 06:03 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
From the looks of it, a Sealand traveller should bolt right in. You might consider the low profile model, since it sits atop the black tank.
Uwe
Old 08-21-2006, 06:11 PM   #3
toastie
toastie's Avatar
1955 22' Safari
Is 3/4" plywood support sufficient?
Old 08-21-2006, 06:20 PM   #4
uwe
418
uwe's Avatar
Images: 40
That's what I used to build the toilet support on my 63 Overlander project.
It seems strong enough, but I did use hardwood ply.
Uwe
Old 08-21-2006, 09:06 PM   #5
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
hello toastie, the sealand toilets are porcelin and made very well .
I have a sealnd traveler lite low profile in our 60 tradewind.
I recommend it.
Scott of scottanlily
scottanlily is offline   Reply With Quote
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 04:07 PM
Thetford Toilet Repair??? Galaxy Low Profile 1985air345 Sinks, Showers & Toilets 8 12-10-2003 07:44 AM
below toilet tod47d Sinks, Showers & Toilets 10 05-05-2003 10:45 PM
Toilet Paper: Is scotts ok? TBKP's Overlander Plumbing - Systems & Fixtures 11 11-29-2002 09:03 PM
Raise the toilet FrankR Sinks, Showers & Toilets 0 03-15-2002 10:57 PM
