Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 11-08-2009, 11:42 AM   #1
serial airstreamist
wheel interested's Avatar
Profile:  2005 28' Classic
Lapeer , Michigan
Images: 117
Exclamation This discussion is going right down the crapper!
My DH is complaining that his porcelin toilet in the Signature has an underpowered flush. What toilet do you have and how's the flush power from 1-10?
Is a new toilet the answer or should we be looking at other possible solutions? It is pretty bad and with the small holding tank of the 23', running the water excessively to flush is a real inconvenience in terms of filling the small holding tank even quicker.
Any thoughts from or for the thinker's throne?
CJ
The future belongs to those who believe in the beauty of their dreams.-Eleanor Roosevelt
It is never too late to be who you might have been.-George Eliot
wheel interested is offline   Reply With Quote
Old 11-08-2009, 11:49 AM   #2
Profile:  1994 30' Excella
Mississauga , Ontario
More bran.
Al
Old 11-08-2009, 11:55 AM   #3
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Carol, we've got a Thetford Style throne, and it does very well in the flushing department.
What do you mean about it being anemic in the flushing department? With liquids, you just open the valve and it drains out. With solid objects, you put some water in it first before opening the bomb bay door...
(No Longer at Inland RV)
Old 11-08-2009, 11:58 AM   #4
serial airstreamist
Lapeer , Michigan
Images: 117
It just doesn't have the amount of water and power that the other Airstream toilets seem to have. It is more a trickle than the burst of water. Even turning on the pump to assist water pressure for city water connection, there is no real flushing power.
Al...he's on All-Bran! tee hee
CJ
Old 11-08-2009, 12:01 PM   #5
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
Well this thread should be an entertaining read....
Some suggestions I've seen in the past to avoid that smudged bowl thing have included waxing the bowl to make it more slippery, keeping a spray bottle of water handy for some targeted cleaning and more effectively, prewetting the bowl with the same spritzer.
Another solution is to put 2 squares of tp down first as a barrier - even wet it works pretty well.
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is offline   Reply With Quote
Old 11-08-2009, 12:01 PM   #6
Well-Preserved
It may be the isolation valve is not open all the way, or is restricting the amount of water going into the toilet. If the trailer does not have one for the toilet, you may need to find a more macho throne for Mr. Wheel...
Old 11-08-2009, 12:29 PM   #7
2airishuman's Avatar
Profile:
technically an RV throne is NOT a "flushing toilet"...
hi C...
i guess u've not shared THIS solution with yer fella...
Help with awning
none of these toilets have "power" in the flush department.
they function like a gallows from old style justice.
hang a LOAD, open the trap door and kerplunk!
the water is PRIMARILY there for sealing the ODORS and lubing the gaskets, trap door and bowl.
and leveling the black hills IN the tank world below.
some folks OVER vigorously clean the bowls,
and SQUEAKY clean is NOT a good thing in this SITuation...
dental appliances are particularly problematic...
Toothbrush Disappears in Toilet!! HELP!
Need Help...Electric Toothbrush in Tank
____________
as noted by others dealing with SKID MARKS...
1. COAT the cleaned bowl with PLEDGE furniture polish (a/s factory advice) per the owners manual...
2. coat the bowl with a VEGGIE SPRAY (lemon or olive or garlic favor, but NOT the hot pepper style !)
3. drop a few squares of tissue in like LINING a bird cage...
4. or use the sprayer. SPLASHER is a betta term. please don't use a water pic (see toothbrush)
5. or START each crap session by FILLING the bowl with water BEFORE sitting...
((the bowl will easily accommodate 1 gallon of water, but bware, dangling body parts may get dunked))
6. dietary changes definitely help, but that's a whole (fiber filled) nother thread...
___________
certainly it's possible the water pump, water lines, internal valving or some other malfunction has developed.
but these porcelain n plastic phones are INTENDED to use very little water.
HOWZ the FLOW when connected to SHORE WATER?
MOST of the water flowing INTO the bowl happens AFTER the trap door has SHUT again..
___________
assuming the mechanicals, plumbing, dietary needs and other basics have been addressed...
well u are dealing with a LONG KNOWN, WIDELY discussed issue...
google 'skid marks and toilet' add the rv term or MARINE/boat words and 100s of cyber threads will be found...
or just quickly read these 2 VERY OLD threads...
it's all been covered b4 folks...
No water to toilet
Sprayer on hose near toilet?
however IF the issue he's dealing has been around THAT LONG,
water alone isn't gonna help with the old BROWN tracks...
ok, gotta go wash my hands now...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 11-08-2009, 01:46 PM   #8
serial airstreamist
Lapeer , Michigan
Images: 117
Oh this has definitely headed in a downward spiral!
Mr Wheel likes the Aqua Magic IV, is it? Hey don't ask me, as long as I don't have to duck behind a tree and watch for hikers I am goood...except for that one time I got caught short, hiking to the lighthouse with the walk around observation deck, that I had not thought about while trying to find cover... Who knew to look UP?
You think I could just feed him lots of saturated oils instead of spraying them into the toilet? Kinda like you put oil in the waffle mix so it won't stick to the iron?
How did I ever step right into this??
Thanks for the tips I am going to enjoy passing them along.
CJ
Old 11-08-2009, 02:34 PM   #9
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
i've dropped a few ice cubes in to jar the load. the higher the launch site, the better the success. BOMBS AWAY!
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
