Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 04-24-2002, 08:59 PM   #1
1985air345
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
Thetford Toilet Repair??? Galaxy Low Profile
I have a Thetford Aqua-Magic Galaxy Low-Profile (WOW! The marketing staff worked overtime for that name) in my 345. The lever only goes back about 95% of the way. The 5% is enough for water to go down and some fumes to come up. I have the parts diagram but I am stuck at where to start. How does that thing come apart to get a better look? I saw the hole plug and removed it. What's the point of that?
The local repair shop won't look at it. Their policy is to sell you a new toilet for $200. I think it may just need some TLC and maybe a new gasket.
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 04-25-2002, 09:17 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Fred. You need to remove the toilet. In order to do so, remove the hole plug, as there is a nut down at the bottom of that hole that must be removed. It will take an extension, on your wrench. You will probably find once you remove the toilet that the slide mechanism is badly corroded. If that's the case, you can replace the entire toilet, or replace just the mechanism. However, installing a new mechasim on a 17 year old toilet is not a good idea. Secondly, for another $75.00 or so, you can get the new toilet instead of just a new mechanism.Andy
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 04-29-2002, 11:28 PM   #3
JW84345
JW84345's Avatar
Profile:  1969 27' Overlander
, Michigan
Fred,
I agree with Andy's assessment. I removed the low profile toilet from my 345 last year because of a leaking valve and bad vacume breaker. I ended up replacing it. Balancing the time to redo it vs the extra $$ to replace it, I chose to replace it.
If you decide to replace it, your choices are limited, you need a low profile. It is just under 13 inches tall. A normal toilet will sit up too high because it is mounted on the platform. I think I paid about $170 for the new toilet at a large local RV store. Camping World was a few bucks cheaper, but much further drive. The new toilet came with all the mounting hardware, including the flange seal. I replaced the water inlet elbow nipple with a straight conversion adpter so I didn't have to make any other plumbing changes.
There are just two bolts. One under the pedals, the other opposite. You can get to the back bolt with a box wrench reaching around back if you don't have an extension handy.
JW84345 is offline   Reply With Quote
Old 12-09-2003, 09:51 AM   #4
nickcrowhurst
Profile:
The tool recommended by Thetford for easy removal of the two bolts under the toilet bowl is a half inch 12 point ratcheting box wrench. These are easily obtainable in sets, costing $50 to $80, but members may be interested to know that the correct wrench is available singly for under $10 from ACE, part # 2067825, a half inch 12 point Ratcheting Combination Wrench, under the trade mark "Gear Wrench". I sprayed the nuts with WD40 the day before, and the bowl came out in 5 minutes work. I suggest this is an ideal tool for an Airstreamer's tool kit. An ideal christmas gift? Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 12-09-2003, 08:42 PM   #5
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
lowes has a set of gear wrench racheting wrenches for $49 or you can buy the single one if you want. i bought the set. and put them in the silver weenie. and that works great for the front bolt nut on the toilet. i use a six point deep well socket taped to a long extension and a 3/8 rachet for the nut in the rear. my paws just dont work to good behind the toilet, too big. not much room.
i say again 1/2 deep well socket tapped to a long extension.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 trailer
PEGGY SUE security dog
wb13798 is offline   Reply With Quote
Old 12-09-2003, 09:54 PM   #6
shelocta
shelocta's Avatar
Profile:
Fred, I feel your pain.
I just went through this to repair the vacuum backer. The pix is looking at the left side of the toilet with the back to the left. You can see where the bolt goes. I use a long extension with a universal joint to turn the bolt. Since it really won't show I decided to cure the nut problem once and for all. After I knew the layout, when I reinstalled it I found that I could get my hand around the back and guide the socket wench.
LOL....bil
Give me 40 acres and I'll turn this rig around.
shelocta is offline   Reply With Quote
Old 12-09-2003, 10:11 PM   #7
shelocta
shelocta's Avatar
Profile:
And now for the rest of the story.
If you are adventurous you may be able to repair the slide valve. My is working ok so I just cleaned and lubed it then reassembled. It looks like you may be able to take it apart and find the problem....bill
Old 12-09-2003, 11:03 PM   #8
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Question flange seal
Can you get the flange seal for this toilet from camping world?
What would I ask for?
When my tank is so full nothing else can go down the toilet, it leaks out the bottom of the belly pan when I go outside to dump it.
As long as I dump before it gets this full, I have no problems. I am hoping the problem is this flange seal.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 12-10-2003, 07:44 AM   #9
1985air345
1985air345's Avatar
Actually, this is an old thread and I replaced my throne with a Bravura model a year ago. No problems since other than paper pile-ups in the black tank so I need to install a tank rinsing piece to rinse the tank better.
I looked at the parts when I took it out and I don't think cleaning up and replacing seals was an option. Lots of corrosion.
Fred H.
Toilet changing tips... drboyd Sinks, Showers & Toilets 2 07-18-2006 02:28 PM
Toilet Repair David Hall Sinks, Showers & Toilets 12 12-29-2003 12:51 PM
64 Swirlomatic toilet MW64OVERLANDER Sinks, Showers & Toilets 1 10-27-2003 10:57 PM
remove/reinstalling the toilet Chuck Sinks, Showers & Toilets 7 07-28-2003 03:44 PM
Thetford Galaxy Starlite free parts! 1985air345 Sinks, Showers & Toilets 4 02-02-2003 05:23 PM
