Old 08-17-2008, 10:58 AM   #1
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Thetford Style II vs. Sealand Traveller Lite
Well, I started the day off measuring toilets, both in the house and the Safari. Hmm... it looks to be an interesting day.
The 75 Safari 23' needs a new toilet. The current model is a stylish gold Thetford Aqua Magic GL and I want to upgreat it new toilet with a residential size seat. The current toilet seat high from the floor is about 18.5", with 8" being the base that covers the black tank and 10.5" height in the toilet themselves. So I'll need the low profile version... and for referance the seat heigth of a standard house toilet about 16.5"... based on my sample size of 3 toilets from 3 different manufactures.
I've done a bunch of searches and while most folks seem to have used the Traveller lite for upgrades, I can't seem to find a comparison with newer small Aqua Magic Style II. Most of comments seem a 18-24 months ago were about the larger depth AM Style Plus in interferance with secret compartment.
The contender for the new throne seem to be the Thetford Aqua Magic Style II and Sealand Traveler Lite.
Now the specs:
AM Style II LP
Flange bolt # 2
Width-seat 15.06"
Height-seat 14.0"
Lenght 20.0"
Flange-center to back 9.5"
Weight 26lbs
Material: china-bowl/plastic
Pedal side: right
Traveler Lite LP 211
Flange bolt # 4
Width-seat 14.875"
Height-seat 12.125"
Lenght 19.0"
Flange-center to back 10.375"
Weight 33lbs
Material: china
Pedal side: left
My observations:
Style II (pluses / minuses)
+ Shorter flange center to back of unit length - won't be crammed to the secret compartment
+ A bit lighter in weight
+ Easy access to the pedal (next to sink cabinet)
+/- No flange conversion, I think. There seems to be a 11o'clock - 5 o'clock flange pattern (vs. 9 -3 o'clock) on older models but have not pulled it check
- Height, with plastic cover the seat would be 22" above floor - 5.5" higher than my house toilets
- Not all china
Travaler Lite (pluses / minuses)
+ lower seat height - 20ish", but still 3.5" higher than house toilets
+ All china construction
- Flange conversion needed - if using the "universal flange" conversion, not sure how much height it adds
- Pedal is now on the far side, right next to closet door
- slightly heavier
  1. So... Has anyone have any opinion on Aqua Magic Style II?
  2. Any thought on how much work is needed ot the flange conversion is on Sealand 4 bolt flange?
  3. How much the universal flange kit adds to the height?
All comments appreciated.
Ron
ronstory is offline   Reply With Quote
Old 08-17-2008, 11:24 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I saw one replacement toilet in a 76 TW that blocked access to the bathroom closet. Something to think about...
Richard
Old 08-17-2008, 11:25 AM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by ronstory View Post
[*]Any thought on how much work is needed ot the flange conversion is on Sealand 4 bolt flange?[*]How much the universal flange kit adds to the height?[/LIST]All comments appreciated. [/SIZE]
Remove toilet, unscrew old toilet flange from top of tank, replace with new 4-bolt toilet flange, if even needed.
No height difference.
If the old toilet flange has 4 holes, you won't need to do a thing.
Some of the original toilets had a plug in teh top casing that you can remove to access the rear bolt..with a socket and extensions.
A possible problem is that the old flange might be very stubborn towards removal. And, you might crack the black tank if you aren't careful.
I have successfully used Sealand porcelain toilets on projects. I do not feel the need to explore other brands at this time, the Sealands work so well, and alre easy to clean. Very little plastic on them. None where it counts.
Good luck with your replacement.
Uwe
www.area63productions.com
Old 08-17-2008, 11:44 AM   #4
2002 25' Safari
Dewey , Arizona
Images: 62
Speaking of toilets.
I am missing one of the rubber pads on the bottom of the seat. If anyone is going to toss a Thetford Aqua Magic, I could use one of those pads. The parts pages at Thetford do not show the pads and I do not need a new seat.
Richard
Old 08-17-2008, 12:42 PM   #5
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
We also used the Sealand and are still happy with it. The old toilet had 2 bolts and the new one is set for 2 or 4. We rotated the old flange to meet the new bolt pattern and used a 2 bolt set up. We didn't use the universal adapter.
The seat that came with the traveler lite (a few years ago) was cheap flimsy plastic. But a standard household toilet seat fit and was an easy replacement.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 08-17-2008, 12:48 PM   #6
Road Ruler's Avatar
Images: 38
We installed the Sealand lite in our 1973 23' Safari.
4 issues
1. It is higher than normal
2. Flange, but adapters make it work (it adds 5/8 in to the height)
3. It is too long at the back and I had to get creative and indent a portion of the back wall to allow it to fit.
4 The flush pedal on the front left sits to far to the left. I had to shorten its mounting bracket so the plastic pedal could be installed and removed if needed without hitting the wall. I have pics somewhere if you want to see the mods.
The sealand works great once installed.
Old 08-17-2008, 12:53 PM   #7
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Richard... when I toss the toilet, the rubber feet are yours... as well as the rest of the toilet.
Ron
Ron
Old 08-17-2008, 12:55 PM   #8
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Going out to do more measurements....
Ron
Old 08-17-2008, 01:21 PM   #9
ronstory's Avatar
1975 23' Safari
Portland , Oregon
OK... here's the scoop
Center of flange to left wall 10.5"
Center of flange to back wall 10.5"
Center of flange to right bath cabinet 11.5"
Front of current toilet to back wall 19.375"
Backrest / secret compat door sticks out 1" from rear wall
Backrest / secret compat door bottom to floor 13.25"
Closet door clearance @ 6" open - dooredge to rear wall is 21" (Thank's Richard for reminding me of that dimension)
... now to look at the diagrams again.
Ron
Old 08-17-2008, 01:28 PM   #10
ronstory's Avatar
1975 23' Safari
Portland , Oregon
All--
Here is the illustration borrowed from the VTS website for the Traveler Lite. Based on the height of 14" at 10.375 rearwards of the flange... the compartment door would ahve to be modifed and would only leave about 0.25" of clearance ot the rear wall.
Now to find some detailed Style II dimensions...
Ron
Old 08-17-2008, 01:44 PM   #11
Janet H's Avatar
1964 26' Overlander
OlyPen , Washington
Images: 90
PPL has a lot of info on their website - maybe you can find what you need here. They have a large collection of schematics. RV Toilets, Holding Tanks & Sanitation
Old 08-17-2008, 05:15 PM   #12
ronstory's Avatar
1975 23' Safari
Portland , Oregon
OK... got distracted by some silicone I missed before...
Back to the toilet... the current Aqua Magic GL is about 19.5 longs and tucks right up to the rear wall. If I use the new Style II, it will give me about 0.75" more room in the back and move the front forward about 1.25" forward, which should allow the closet door to still open. Now the problem is that it's 3.5" taller... which will interfer with opening the secret compartment door... and I'll probably need a build a platform to put one's feet on. (sigh)
Life is never simple.
Ron
Old 08-17-2008, 06:55 PM   #13
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
We put a Style II in our Sovereign (high profile), a caveat is that the plumbing standards have changed in the last 30+ years. You will need to change the fitting from the pipe to the toilet (for any new toilet).
Old 08-17-2008, 07:16 PM   #14
2002 25' Safari
Dewey , Arizona
Images: 62
My closet door clears the toilet by almost 3 inches, you should be fine. I did not find out about the secret door until about a year after I bought the trailer. Went down a bumpy dirt road and it opened up. The PO left me a nice plastic mug from ghost ranch. Thanks Ken...
Richard
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
old style brake conversion to new style Justmeandshe Brakes & Brake Controllers 1 06-23-2007 05:16 PM
Great Deal on Sealand Traveler Lite Toilet Bob Thompson Sinks, Showers & Toilets 3 02-20-2006 08:50 PM
sealand lite problems emanon25 Sinks, Showers & Toilets 12 08-31-2004 12:43 AM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
