Old 10-28-2006, 11:54 AM   #1
bwjohnson's Avatar
1966 30' Sovereign
Monroe , Iowa
Thetford Slide-Ez toilet valve repair
Hello, Anyone know what the fitting on the top of my '66 AS toilet's gate valve does (see picture)? It appears to vent the black water tank into bowl of toilet?? I bought a seal kit #03827 that came with a new stainless steel plate that does not have this fitting. Looking around there is a different kit #09872 that shows a lip seal not attached to a ss plate. I wonder if and how this could be attached to my ss plate with a fitting.
First post, please help,
Brian
bwjohnson is offline   Reply With Quote
Old 10-28-2006, 12:00 PM   #2
bwjohnson's Avatar
1966 30' Sovereign
Monroe , Iowa
Brain fart, duhh. Is this an overflow for the toilet? If it is can I plumb this somewhere else, say into the gray water or out on the ground?
Brian
Old 10-28-2006, 01:38 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Hi Brian,
Welcome to the forum. Your toilet does not have an overflow (other than onto the floor ). Once the black tank gets full, the toilet will not empty when the pedal is pushed.
I have a very similar SLIDE-EZ valve on my '67 Airstream, and it does not have the fitting pictured in the top, left-hand corner of your picture. The only thing I can think of is that, since your valve is mounted horizontally, the mystery port is a vent for moisture that gets trapped between the plastic & stainless parts of the valve. My valve is mounted vertically and serves to drain the black tank.
Hopefully others will chime in.
Tom
Old 10-28-2006, 03:09 PM   #4
rideair's Avatar
Not sure how it works, but I think it has something to do with adding water to the bowl when flushing the toilet. There is a clear tube that runs from this connector to the back side of the toilet. If you plan to flush the toilet using the hand sprayer, I would think you can plug both ends of the connection. Were did you get your rebuild kits?
Paul Waddell
rideair is offline   Reply With Quote
Old 10-28-2006, 05:31 PM   #5
bwjohnson's Avatar
1966 30' Sovereign
Monroe , Iowa
Tom, What I mean by an overflow, is that if the water level in the bowl got too high for some reason(valve sticking on) it would run back to the tank around the gate valve. It seems to me that this would also let gasses out into the bathroom. I put water through the hose that connects to the toilet and it came out a hole in the back of the bowl. The only thing that it can be is an overflow.
This now seems to be the least of my problems. I was planning to patch the rotten floor under my toilet area and pulling out the soft wood revealed a crack in the black water tank. I took it out (not an easy job) and broke the vent pipe off the far corner of the tank, not that I could have fixed the first crack. Now I need to find a new tank. I don't enjoy camping this much.
Brian
Old 10-28-2006, 06:49 PM   #6
rideair's Avatar
Brian,
From what I understand, Andy at InlandRV sell the tank new.
Paul Waddell
Old 10-28-2006, 08:44 PM   #7
bwjohnson's Avatar
1966 30' Sovereign
Monroe , Iowa
Ya, I saw Andy's fiberglass tanks for $445. If mine were fiberglass it would be easy to repair, but it looks like vacuum formed plastic. Iv'e never done plastic welding before. I'll probably end up buying one, but have considered making one out of stainless. That would last forever.
Thetford Toilet Repair??? Galaxy Low Profile ViewRVs Sinks, Showers & Toilets 11 05-03-2010 03:27 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
Toilet valve problem Charles Q Treichel Sinks, Showers & Toilets 1 09-04-2002 10:59 AM
