Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 12-11-2005, 03:44 PM   #1
handn
Profile:
Thetford one pedal no water blues
Is anyone else having trouble getting the bowl on their Thetford one pedal toilets to fill with water.
If I push the pedal hard enough to get any significant water flow it opens the slide and the water runs out.
Is there a fix or do I have to carry the one gallon jug of water around that I use to fill the bowl?
Even the top of the line Thetford china bowl toilets are one pedal. Not a better idea in my opinion.
handn is offline   Reply With Quote
Old 12-11-2005, 03:50 PM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Have you tried lifting UP on the pedal? That's how my Sealand works.
Tom
Old 12-11-2005, 04:29 PM   #3
mandolindave
mandolindave's Avatar
Profile:
I think you might come to appreciate the design. Sometimes you don't want the bowl to fill with water. For instance, if you are going to be traveling and
don't want water splashing around, or if you are boondocking where water conservation can prolong your stay.
............there are some other issues but.......EEWWWWW
mandolindave is offline   Reply With Quote
Old 12-11-2005, 05:26 PM   #4
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
There must be something wrong with your valve mechanism. I just replaced a 2 pedal with a new 1 pedal Bravura. It works just ducky!!!
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 12-11-2005, 07:29 PM   #5
cammur
cammur's Avatar
Profile:  2005 25' Safari
Roseville , California
Mine acts the same way, filling with maybe a half-inch or inch of water, but I don't think it needs more than that to make a seal. For flushing purposes I just hold down the pedal as long as necessary.
cammur is offline   Reply With Quote
Old 12-21-2005, 08:40 AM   #6
handn
Profile:
Unlike Sealand toilets, new model Thetfords don't fill with water when you hold the pedal up.
Has anyone had any luck adjusting a one pedal Thetford to fill properly?
Old 12-26-2005, 01:04 AM   #7
SilverToy
Profile:  1992 34' Limited
Falls Church , Virginia
1 Peddle, sprayer question
Hi all -
Have the 1 peddle Thetford herein described. I DO NOT however have a handy little sprayer on the hose to 'clensify' after ... Is this common with the 1 peddle models?? Is there a fix to add a sprayer - or do I even need one?
Curious???
Axel
SilverToy is offline   Reply With Quote
Old 12-26-2005, 05:38 AM   #8
Pick
Pick's Avatar
Images: 36
I just purchased mine about a month ago. It DID come with the sprayer hose. I think I see what you folks are talking about, now. Mine fills up to a certain point, which is enough to "do the job", but no further. I did like the dual pedals for dumping the tank. I could fill the bowl to the point of overflowing, then dump it. I felt this method helped clean the tank and pipes better. Now I have to hold the single pedal all the way down and just let the water run in. I don't see any way of adjusting the pedals on mine.
Lots of Hot Sauce!
Air # 283
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water problems Dbraw Fresh Water Systems 13 06-28-2007 04:55 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
