Old 11-01-2006, 05:51 PM   #1
gparker's Avatar
1970 31' Sovereign
Denham Springs , Louisiana
Thetford Galaxy removal
OK, I have searched and not been able to find step by step directions for removing the toilet in my 1970 Sovereign. The flush valve works great, but the supply line is leaking. Wouldn't repairing the leak be much easier if I removed the toilet? If so, how do I get at the bolts? How many bolts are there? I can see the front bolt, but I don't understand how to access the rear bolt or bolts. My toilet doeas not have the removeable access hole cover on the seat. AN EXPLODED DRAWING WOULD BE VERY NICE...
Greg
gparker is offline   Reply With Quote
Old 11-01-2006, 06:35 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Just pulled the toilet from a 71. Knuckles are still bare. After the two bolts were finally out I couldn't get the suppy line loose - ended up cutting the copper feed line off.
For the reinstall - bought a flex head wrench from Lowes that will fit down into the rear bolt hole. Trailer has all copper plumbing but will replace the feed line with reinforced hose that is used to supply dishwashers to get enough length.
Good luck.
Old 11-02-2006, 03:55 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Greg,
Two bolts - one in the front you found and one opposite in the rear - marked by the red plastic inserted into the bolt hole.
Name:	Galaxy Toilet 001.jpg
Old 11-02-2006, 03:59 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Your post said you did not have an access on the top of the toilet. Check to be sure you don't have this. If you go this way you need a 12" extension for your socket wrench and a swivel attachment. You will also need a deep well socket - which I didn't have with me while removing our toilet.
Name:	Galaxy Toilet 002.jpg
Old 11-02-2006, 04:03 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Here is the wrench that I bought to reinstall the toilet next spring. You will also need a new gasket (house equivilent of a wax ring) when you reinstall.
Good luck with your project.
Name:	Galaxy Toilet 003.jpg
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 01:48 PM
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
Thetford Toilet Repair??? Galaxy Low Profile ViewRVs Sinks, Showers & Toilets 11 05-03-2010 03:27 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Wardrobe Removal ??? 54FlyingCloud General Interior Topics 1 07-25-2002 02:22 PM
