Old 07-01-2011, 08:24 AM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Thetford Aqua Magic Style Plus?
I currently have a low profile Thetford Bravura toilet that is a little higher than I like, it has a water leak and the flapper will not retain water even though the seal has been cleaned. I am thinking about replacing it with a Thetford Aqua Magic Style Plus which is slightly shorter but not by much. I've searched the forum and seen plenty of suggestions on toilets but not much on this china bowl model. Any input regarding this model?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-01-2011, 09:09 AM   #2
Weldon Spring , Missouri
I had one for a while, Craig.....it worked fine, but the bowl "coverage" (when flushing) was not as good as advertised. And, I would think it would fit anywhere a Bravura would fit.
fmr.capt.evi is offline   Reply With Quote
Old 07-03-2011, 10:11 PM   #3
davidz71's Avatar
1986 25' Sovereign
I appreciate the response. I did some further research and saw that there were more positive comments on the SeaLand Traveler 500 plus series of toilets. I chose the low profile model which is around an inch lower that the low profile Bravura and got it for $248.88 with free shipping/no tax.
Craig
AIR #0078
3.73 rear end
looking for help with Magic chef oven pilot light jayg Stoves, Ovens & Microwaves 2 06-01-2011 04:18 PM
Broken Thetford Valve Handle casa3805 Waste Systems, Tanks & Totes 4 04-23-2011 06:20 PM
Is it Electricity or Magic? casa3805 Electrical - Systems, Generators, Batteries & Solar 18 04-12-2011 04:16 PM
Regular style light bulb that works off of 12 volts Dan@LED4RV Commercial Listings 0 03-24-2011 12:49 PM
Magic chef oven Airstream76 Stoves, Ovens & Microwaves 15 01-25-2011 11:38 PM
