Old 01-27-2012, 06:05 PM   #1
Thetford Aqua Magic pedal push won't fill bowl.
My Thetford Aqua Magic won't fill the bowl when the pedal is pushed part way. I have to push the pedal quite a ways and by then the valve on the bottom of the bowl is part way open and the water runs out. Is there a fix? I had the cover off and didn't see an adjustment.
handn is offline   Reply With Quote
Old 01-27-2012, 07:01 PM   #2
sandlapper's Avatar
1993 34' Excella
York , South Carolina
If I remember correctly there are 2 cables inside the toilet. They are much like the cables on the hand brake on a bicycle. Stepping on the pedal pulls the cables and gets things moving. One hooks to the blade , the other to the water valve thing. Each has a stop or "keeper" that tightens down on the cable. Sounds like one of them may have loosened and slipped. I had to remove the toilet and take it apart to access the cables. I purchased a rebuild kit from Camping World, it had new cables, keepers, and some other stuff . If you have to remove it and take it apart, may as well put in some new parts. Hope this helps.
John, the #1 man for the# 2 job!.
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 02-03-2012, 08:38 AM   #3
I fixed the problem by replacing the water valve. A messy, unpleasant job but not difficult. My toilet was a Style Plus and not an Aqua Magic. Style Plus and Lite water valves are different and not as common. It may be a special order. I purchased two so I have one for a spare.
Old 02-04-2012, 08:07 AM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
What model Aqua Magic is it? May be a stupid question but, if your model is equipped with a two part pedal - you are just pushing the smaller outer pedal to add water? - not both pedals.
Thetford waste valve replacement Safari64 Plumbing - Systems & Fixtures 6 02-24-2012 08:32 PM
Aqua Magic V in '64 TW ~ Help! Tabasco Plumbing - Systems & Fixtures 3 01-30-2012 12:46 PM
Need advice on removing City Water Fill on 1994 Limit Don McKelvay Fresh Water Systems 2 11-01-2011 10:47 PM
Thetford Style II toilet model 42059/replacing Lothlorian Sinks, Showers & Toilets 4 08-23-2011 05:07 PM
Thetford Aqua Magic Style Plus? davidz71 Sinks, Showers & Toilets 2 07-03-2011 10:11 PM
