Old 09-11-2007, 08:16 AM   #15
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
wasting money!
I really do not like wasting money.
Why flush good greenbacks down the drain. Use the cheap stuff, poke your finger thru a few times----
Oh I see a thread just below this one titled "wiper arms" gotta check it out and see if it is revelant to this topic!
ah yes morning coffee entertainment
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 09-11-2007, 09:53 AM   #16
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
Back issues of the Blue Beret
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 01-31-2008, 12:11 PM   #17
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Charmin Toilet paper
I just got off the phone with a person from Charmin and they told me that they have done testing with the charmin basic and it can be used in the black tanks with no problems in all RV's.They told me not to use the other ones they sell because they have not tested them yet.
Right now I have swithed to scott's but if I think I will be trying the Charmins once I run out of these.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 01-31-2008, 12:51 PM   #18
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Angel Soft
Three Rivettes standing around my unit... watching a demonstration of the "Sewer Solution" which is a one inch dump hose with a water pressure "mascerator". One remarks, "Gee standing around watching someone else's poo drain... I feel like we're Hank Hill and his buddies standing in the alley..." The other two respond, "yep" and "yep". Then I remark, "you know seriously most of what I learned about propane safety came from Hank Hill..." responses of "yep" and "yep" yet again.
Long story short, I've come to the conclusion that (A) sanitizing your black tank is an oxymoron because you're only one tinkle away from messing it up again and when traveling I would use my own facilities in preference to any public pissoire and (B) agitation is more effective that washers, wands, backflowing clear water in through a connector nozzle, etc. I get my tank as empty and clean as is practical in a reasonable amount of time, then I dump in 3 or 4 gallons of clear water and TRAVEL. At the END of the journey I empty the black tank again.
I've once flushed my tank for 30 minutes (something came up and I got stuck on the cell phone). When I arrived at my next destination three hours later I opened the valve for the black tank and some brownish liquid still came out. If I didn't fulltime, at the end of the season I'd put 5 gallons of clear water and a couple of cups of Clorox in it, then drive and dump, then repeat with clear water and drain thoroughly. As long as I'm actively using it, I'll dump, partly fill, drive and dump again. Can you say "scrubbing bubbles?"
Paula
Old 01-31-2008, 02:13 PM   #19
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
We use charmin. I am careful to flush the tanks with a wand on the end of the hose often. I also periodically fill the black tank to about 1/3, and add laundry detergent just before leaving on a trip. This seems to slosh and clean the tank enroute. I then dump before camping. This keeps things clean, and helps minmize ordors.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-31-2008, 04:04 PM   #20
2007 25' Safari FB SE
Evergreen , Colorado
What chemicals do you find work best?
Allen H is offline   Reply With Quote
Old 01-31-2008, 05:10 PM   #21
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Unique Digest it. Colorado Company. One use cleaned a tank that had set for at least 4 years and likely much longer. Also sofened the seals so I could get the valves open. Unique M and M -- Home
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 01-31-2008, 05:20 PM   #22
1972 25' Tradewind
Madison , Wisconsin
I have actually had a couple of phone calls about this. (I am a regional Septage Coordinator for the WI DNR.) Most single ply toilet paper is considered "septic system compatable", meaning it will break down.
Use basic TP like Scott, Charmin or most others. Save some $$. It is rare that these will pack up even in an RV tank. The TP should start to break up after just a few hours. Even most multiple ply TP's will not be a problem. Many years ago there were compatabiltiy problems with some types, even back then it was generally not much of a problem.
Smokin Camel is offline   Reply With Quote
Old 01-31-2008, 05:38 PM   #23
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I'd spend a lot of extra bucks believing it would prevent issues (tissue issues?) down the road. A no-brainer for me. After all, how much would you really save by not springing for the high-priced spread?
But I will say that I'd only use Scott in the trailer, not at home. I hate the one-ply stuff.
Pat
pmclemore is offline   Reply With Quote
Old 01-31-2008, 05:38 PM   #24
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
TP affecting tank readout?
With all the complaints about the tank sensors not reading accurately, could toilet paper sticking to the tank interior explain erroneous black tank readings?
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 01-31-2008, 05:44 PM   #25
Devoman's Avatar
Tank Sensor
If anyone feels toilet paper is sticking to the sensor they can unscrew it from behind the dump valve outside and check it out.I did this when I had a leak from it a while back and found some little critters hanging out on it.How they got in,I will never know.
Just remember to empty the tank before you check it or you will get one hellasious burp from your black tank.
Old 01-31-2008, 05:47 PM   #26
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
First of all, I have to note the name of the poster of the above quote. Quite appropriate.
I was going to say "Sears Catalog" but that might date me.
Old 02-19-2008, 08:59 AM   #27
SnowGypsy's Avatar
Fort Scott , Kansas
The Water In The Jar Test
Surpirsed no one mentioned the water in the jar test. You take a jar of water and put a couple squares of the TP in and shake it, let it sit and shake again. This will give you an idea of how it will or will not break down. We full-timed for 4 years in non-Airstreams and used both Angel Soft and Scott one-ply without any problems. We always followed emptying the tanks with a bucket or two of water to "chase it" down. We didn't use chemicals unless we weren't using a lot of water and then we used one of the natural ones with a little additional baking soda in extreme heat. You have to be careful of some of the ones with formaldehyde because if you are like me and some others the vapors will give you a major headache - I don't want to preserve the stuff in the tank anyway, yuck! Cathy
SnowGypsy is offline   Reply With Quote
The Great Frame Debate Becky B. Repairing/Replacing Floor &/or Frame 20 05-01-2007 07:44 PM
Toilet paper and other things campcollector Waste Systems, Tanks & Totes 45 12-08-2006 09:22 PM
Important papers: toilet paper cover Safari64 General Interior Topics 15 03-17-2006 07:04 PM
The Great Towing Debate Continues... Chuck Towing, Tow Vehicles & Hitches 9 04-30-2004 01:20 PM
Toilet Paper: Is scotts ok? TBKP's Overlander Plumbing - Systems & Fixtures 11 11-29-2002 08:03 PM
