Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 05-24-2005, 04:49 PM   #1
1958 Globetrotter
Profile:
Stool flange
I am in the process of replacing the tile in my 1958 Globtrotter. I have removed the porcelain stool in the W/C but can't seem to get the cast iron base to budge. The base is secured to the subfloor (plywood) by 4 screws which I have removed. The stool sit directly on top of the black water tank with the subfloor between. Does anyone know how to remove the cast iron base from the black water tank? Is it threaded? Looking for knowledge before I put too much elbow grease to it and break something.
1958 Globetrotter is offline   Reply With Quote
Old 05-24-2005, 05:14 PM   #2
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Welcome to the forums. Do a search on cast iron using search tool above. Seems like a read someplace here that 50's model cast iron stuff is odd sized and hard to find nowadays. My '73 has a threaded (plastic) flange. Just rotate it counter-clockwise to remove. Not sure how cast iron stuff works. One of the great things about this site is that somebody will know and give you the info in short order.
To lodge all power in one party and to leave it there is to insure bad government. -- Mark Twain
www.nesa.org
Air No. 6427
Old 05-24-2005, 05:27 PM   #3
markdoane
Profile:  , Minnesota
Images: 59
The black tank on my '59 has a 3" threaded brass nipple, but the flange itself was ABS. I would soak it in Kroil for a day then try it again.
If it's cast iron against brass it could be a nightmare.
Non-contributing deadbeat.
Toilet recommendations, please! drboyd Sinks, Showers & Toilets 27 02-16-2005 08:54 PM
HELP - Removing Toilet Flange Barkingspider Sinks, Showers & Toilets 4 07-12-2004 11:10 PM
Toilet Flange Sneakinup Sinks, Showers & Toilets 16 06-30-2004 04:16 PM
Glue or clamp flange to black tank? pilgrim_still Waste Systems, Tanks & Totes 8 07-12-2003 08:21 PM
Black Water inlet flange Dave Shanahan Waste Systems, Tanks & Totes 1 08-18-2002 04:09 PM
