Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 10-11-2005, 08:55 AM   #1
dsakaki
Profile:
Spray-in truck bed liner for shower tank?
Hello all,
I am starting a custom reno on a 62 Safari. I want to build a shower in the rear corner of the trailer. I was pondering the possibility of constructing the tank out of thin plywood and waterproofing it with a sray-in truck bed liner. Has anyone tried this? I will visit a few spray-in dealers today for more info. I would love to hear from anyone with info, pros/cons, or other suggestions.
Thank you in advance.
David
dsakaki is offline   Reply With Quote
Old 10-11-2005, 09:09 AM   #2
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
buy a bath
Originally Posted by dsakaki
Hello all,
David
David, I'd call the factory first. I don't see why a current corner bath or wet bath enclosure wouldn't work. Why not go for fiberglass? Lighter, won't rot or attract insects, etc.
Tin Lizzie
Old 10-11-2005, 10:50 AM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
It would be non slip!
I don't think I would do it. The wood will dry out and shrink after a few years (a few days if you live where I live) and the seams may crack and leak. I would go with the fiberglass option. The last thing you wank is a leak and then rotting floor under it!
BTW, I had an Inyati liner sprayed into my TV bed. These guys were pros. I would highly recomend them.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 10-11-2005, 11:37 AM   #4
dsakaki
Profile:
Thanks for the replies,
I wasn't aware that one could purchace a fiberglass unit from the factory. I will definately check into that.
Thanks again
David
Old 10-11-2005, 03:30 PM   #5
juel
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Anyone tried the one coat, self-leveling polyeurathane to redo the sink and shower. I have the white coat but this stuff comes in colors and is intended for boat decks. I can't see why it wouldn't work since the discolored fiberglass would be under it. I wouldn't be tearing anything out. I'm looking at Epifanes One Part Mono Urethane or Toplac, out of the Jamestown Distributors catalog. Any suggestions?
juel is offline   Reply With Quote
Old 10-11-2005, 09:01 PM   #6
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Sounds feasible. I know someone who had the deck of his riding lawnmower sprayed after he bought it to prevent rust and I have read of people spraying the floorboard of Jeep CJ5 and CJ7 vehicles. They also claim you can spray the floor of horse trailers. LineX seems to have a finer grain than Rhino Linings which looks more like cottage cheese.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 10-12-2005, 12:56 AM   #7
tmcdougald
Really Cheap
tmcdougald's Avatar
Profile:
Durabak,This is good stuff, it comes in bumpy and smooth. Many colors too
Heres the link
Jevons paradox: Increases in efficiency lead to even larger increases in demand.(Basically means that there is no hope for the energy and resource problems on this planet.)
tmcdougald is offline   Reply With Quote
Old 10-20-2005, 07:02 PM   #8
Chris Holt
Profile:  1960 18' "Footer"
St. Clair , Michigan
AZFLYCASTER, Do you or anyone know if one of those Fiberglass Showers would fit a 1960 Caravel , I have to go pick it up next week , and I'm going to reconfigure the interior and thought if I could fit one in I would.
Chris Holt is offline   Reply With Quote
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 07:11 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 01:57 PM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 09:52 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 05:17 PM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 09:14 PM
