Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 09-07-2008, 01:00 PM   #1
Tim Can
Bambi Hunter
Profile:  1977 Argosy Minuet 6.0 Metre
Los Angeles , California
SOB broke my Aqua Magic III toilet!
My '77 Argosy has the Aqua Magic III toilet, and it's in pretty good shape. I made the mistake of allowing an SOB camper to use my head and now, the hand flush mechanism has water spewing into the air (and ultimately on the floor) when it is flushed. The water comes through the opening in the top (the translucent hard plastic unit right under the hand flushing turn knob) and appears that the mechanism to close the opening is not functioning properly. Some of the water is diverted into the bowl, but more is an unwelcomed shower.
I've checked for repair kits. However, I wanted to be sure I'm getting the correct kit. Is it the ball valve that needs to be repaired?
Can't say the SOB is fully responsible, but it's fun to blame them anyway. Thanks.
Tim
Tim Can is offline   Reply With Quote
Old 09-07-2008, 01:16 PM   #2
Safari-Rick
U.S.Navy Retired
Safari-Rick's Avatar
Profile:  2005 25' Safari
Lakewood , California
Tim, Tim, Tim, why would you allow anyone else other then another AStremmer to use the commode? Shame, shame on you ~!
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 09-07-2008, 02:04 PM   #3
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
Maybe you could use it for a bidet. Tres chic.
Like a couple of Balboas we headed into the wild pavement of yonder with a monstous piece of aluminum hooked to our rear end. "The Long, Long Trailer".
Old 09-07-2008, 02:39 PM   #4
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Tim
Some parts are still available, but only from dealers that are familiar with your vintage toilet.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 09-10-2008, 02:21 AM   #5
Tim Can
Bambi Hunter
...And the winner is...Bidet! Thank you all for playing.
Rick, I should have known better, but they snuck in while I was out hiking. I better check the walls to make sure they didn't stretch the aluminum trying to find a "pushout".
Well Andy, if you can't direct me to the right part to fix the toilet, looks like I'll be forced into having the freshest derriere in the park. I'll have to watch my back during our performance of "YMCA"!
Tim
Old 09-10-2008, 10:16 AM   #6
Commercial Vendor
Tim
When you "touch" that cast base, be prepared for it to crumble.
Next problem, is that cast base has not been available for about 38 years.
Change the entire toilet now, and save yourself much grief.
Be very careful which one you select since you will also have to modify the fiberglass bench, to make your selection fit.
Inlandrv.com
800-8777311
Old 09-10-2008, 07:20 PM   #7
Tim Can
Bambi Hunter
Thanks Andy. That seals it. We only "parle vous frances" from now on. Those without a bidet are simply uncivilized.
An Airstream without a bidet is like an SOB without a geothermal gyroscopic satellite tracking station. Wouldn't be caught drunk without it.
Old 09-10-2008, 07:41 PM   #8
eubank
Lynn
Commercial Vendor
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
Originally Posted by Inland RV Center, In View Post
When you "touch" that cast base, be prepared for it to crumble. ... Andy
Most true! My dad has an older SOB Class C. The toilet had turned into plastic junk, and I had to get him a complete new one.
The good news was that I found him a brand-new (NIB) one on E-bay for a darned good price. It was just dumb luck that I happened onto E-bay at that point.
Lynn
WBCCI 21043
Lynn's blogsite: http://forum.aardvarkrv.com/blog/
If you're WBCCI, come visit us at the park (and get more cool air and less oxygen and ... a 50% discount!)
Old 09-10-2008, 08:03 PM   #9
Commercial Vendor
Me either.
Inlandrv.com
800-8777311
1972 Thetford Aqua Magic 30 cameront120 Plumbing - Systems & Fixtures 5 05-19-2007 08:59 PM
1972 Thetford Aqua Magic 30 cameront120 Sinks, Showers & Toilets 2 04-25-2006 09:19 PM
Replacement Toilet for Thetford Aqua Magic? JeepinAudiophile Sinks, Showers & Toilets 1 09-20-2004 12:05 PM
toilet:Sealand vs Aqua Magic dogwood Sinks, Showers & Toilets 8 09-02-2004 08:46 PM
Aqua Magic Toilet - 68 Globe Trotter Bryanhu Sinks, Showers & Toilets 0 06-30-2003 02:29 PM
