Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 05-02-2007, 01:55 PM   #1
Radman
Radman's Avatar
Profile:  1972 27' Overlander
Monterey Bay , California
Images: 95
Slip Fitting On Top Of Black Tank To Toilet
I recently purchased a new black tank for the 72 overlander. I however ordered it with a 3" slip fitting that has a verticle lip of about 4.5" that sticks up from the top of the tank. No threaded (female) receiver for a threaded flange to secure the toilet to the tank. Live and learn. I guess if this is the worst thing that happens in my rennovation/ restoration than I am in good shape. BTW the tank is made of plastic and currently the floor is out as is the new tank. So access is not a problem. The new toilet that will replace the old one will also have a threaded flange set up like the old tank had.
Do I grind this thing flush with the top of the tank and epoxy or glue a new inlet adapter in it's place of what? Anyone dealt with this one before? What are my options at this point. I hope I have given everyone enough info. to get a wee bit of help. No pun intended.
What to do? What to do? I just want to do it right the first time. Thanking everyone in advance.
Radman is offline   Reply With Quote
Old 05-02-2007, 02:06 PM   #2
markdoane
Profile:  , Minnesota
Images: 59
If it's a 3" slip fitting, you should be able to slip a 3" ID ABS tube inside of it. Glue a closet flange on top of the 3" ABS and you should be able to make it work just fine.
You can shorten the 4 1/2" extension to about 2", enough that you can get two big hose clamps on it. I usually heat the slip fitting with a hot air gun to soften it up a little before I tighten down the clamps.
Non-contributing deadbeat.
Old 05-02-2007, 03:26 PM   #3
Radman
Radman's Avatar
Images: 95
Now that is a great idea! Why didn't I think of that? Thank you for your help.
Old 05-02-2007, 04:11 PM   #4
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
Looking at cracking pattern around the threaded flange of my old BW tank, I will be tempted to add weight to tank interior before any final toilet mount & pipe fitting occurs - allow everything that can crush down to get it over with, tank wall flex, hangers & box and insulation.... if there is rebound better to have empty tank weight pressing up then full tank hanging and bouncing; BW tank capacity is 17 gallons so 140 pounds of clean HOT water in tank and a few hours to settle before final fitting for this camper!!
Attachment failed; it was clean-ish BW tank flange...
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Clear coat finish on top James Schmidt Clearcoat, Exterior Paint & Trim 7 06-14-2006 10:26 PM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 04:08 PM
cleaning up toilet tank release handle cindy Sinks, Showers & Toilets 0 10-19-2002 12:44 PM
Leak somewhere in top section- B190 Van Luckydog Sprinter and B-van Forum 2 10-16-2002 09:39 PM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 01:57 PM
