Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 09-19-2014, 05:42 PM   #1
1999 28' Excella
New Orleans , Louisiana
Sink drainage is slow
Is there a combination of household products that can clean the drain a little to drain better? Getting a little slow. Thanks
badkat is offline   Reply With Quote
Old 09-19-2014, 05:58 PM   #2
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
try baking soda and boiling water
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 09-19-2014, 06:00 PM   #3
L&C Woogie's Avatar
1979 25' Tradewind
Mt. Vernon , Washington
Images: 30
Just fixed the same problem. Tried a snake from the sink to the grey tank but got stopped somewhere so I got a gizmo you hook to a water hose. It fits in the sink drain hole and expands and forces water under pressure to clean the pipe. Worked like a charm. Now have great quantities of clear water coming out the drain. I was a little worried about the pipe exploding but it didn't happen. Got the gizmo at ACE but it is probably available at the big box stores also.
Good luck.
L&C Woogie is offline   Reply With Quote
Old 09-19-2014, 07:33 PM   #4
richinny's Avatar
2011 34' Classic
baking soda and vinegar floshed after sitting a while with hot water, works for me. i'm not daring enough to use boiling water.
Ricky
Old 09-20-2014, 12:32 AM   #5
2004 16' International CCD
Chicagoland , Illinois
Have you tried cleaning the trap? Also, sometimes lots of gunk accumulates around the bottom side of the drain. A think piece of wire, maybe a toothbrush, etc. could be pushed down the drain from above to clean the first 8 inches of drain pipe.
Good luck!
Airrogant is offline   Reply With Quote
Old 09-20-2014, 05:43 AM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
You could also just disassemble the trap (putting a buckets or pan underneath when you take it apart) and clean it out by hand. If the trap is clean then you likely have some blockage downstream and the power rodding approach mentioned above should work.
If you must use the chemical approach, I would suggest the baking soda and vinegar system previously mentioned. I would hesitate to use harsh chemicals such as Draino or lye since there are some potentially sensitive parts to your plumbing system that do not exist in a typical home environment.
Bob Martel
WBCCI# 5766
Old 09-20-2014, 06:26 AM   #7
Piggy Bank's Avatar
Also, there is this really handy thing I use for home drains.
It's about $5. Got it at a local "old guys" hardware store.
It looks like a really long (maybe 18 inch long) plastic zip tie with teeth/barbs on it, with a loop at the top to hold it. You insert it down the drain and then pull it back out towards you. The barbs catch hair and soap bits and bring them back up. And re-useable. A great use of $5. Especially for anyone with old plumbing in their house that you don't like to pressure plunge.
Piggy Bank
Old 09-20-2014, 06:47 PM   #8
1999 28' Excella
Baking soda, vinegar and hot water..is magic!
Old 09-20-2014, 07:47 PM   #9
richinny's Avatar
2011 34' Classic
smells good too!
Ricky
Old 04-16-2022, 01:12 PM   #10
Revery's Avatar
2014 23' Flying Cloud
2015 28' Flying Cloud
Laguna Niguel , California
What Proportions of baking soda vinegar and hot water?
Revery is offline   Reply With Quote
Old 04-17-2022, 06:02 AM   #11
2019 30' International
Pennsylvania , Pennsylvania
Yep, I'd get in under that sink and take that trap apart to see what's in there. It's really an easy job. Like you said, have a basin in under there, and a towel, and you're good to go.
No, No, to drain O
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 04-17-2022, 06:28 AM   #12
dznf0g's Avatar
Oswego , Illinois
This is the best answer, IMO. Sometimes you need to remove the stopper to really git 'er done.
https://www.amazon.com/Zip-Drain-Cle...36918151&psc=1
-Rich-
Old 04-17-2022, 07:08 AM   #13
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
just remove the trap, take it apart and clean it, the shower trap is impossible to get to so I put a valve stem on a rubber stopper, poured vinegar down the trap, let it set for 24 hours then put the stopper in and put 50 psi air pressure thru it, works. By the way that's what the mfg. recommends, using air pressure
rbs is offline   Reply With Quote
Old 04-18-2022, 06:57 AM   #14
The Aluminum Tent 3
pcskier's Avatar
Park City , Utah
Shower trap is usually easily accessible via removable panel under the belly.
pcskier is offline   Reply With Quote
Old 04-19-2022, 05:36 AM   #15
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
maybe yours has an access panel, mine doesn't. There is an access thru the cutout in the wall panel, but impossible to get anything inside to work on it, hence the "solution", air pressure
ABS drainage system - 2005 Classic RoadToad 2001 - 2005 Classic 16 01-29-2009 01:36 PM
Urgent vintage grey water drainage question! 1959newbie Waste Systems, Tanks & Totes 6 04-21-2007 09:58 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
Water Tank Drainage popeyedoyle1 Fresh Water Systems 8 03-07-2006 04:50 PM
16' ccd Bambi drainage system question. gbrentsmith Waste Systems, Tanks & Totes 12 10-17-2005 09:08 PM
