Old 09-19-2014, 09:11 PM   #1
Okiestreamer's Avatar
1999 25' Safari
Adair , Oklahoma
Shower water temperature fluctuations
While dry camping, our shower water temperature fluctuates with the water pump cycles. When the pump is running, the temperature stays as you set it but when the pump pauses it only pumps cold water. When the pump comes back on, the water temp returns to what you have set. We added an accumulator tank which helped a little but did not eliminate the problem. I've thought about replacing the cartridge in the control but can't see how that would cause this problem. Has anyone had this problem and, if so, how did you solve it? We have a '99 Safari.
Dave
Okiestreamer is offline   Reply With Quote
Old 09-19-2014, 09:32 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
My guess would be a restriction in your hot water system somewhere. Set your shower to all hot and turn on the pump. Pump into a bucket and see how much water you get in some time, say 30 seconds. Then do the same with all cold. If they are not close there is a restriction somewhere. When the pump goes off, pressure drops and the flow in the restricted line drops faster than the unrestricted.
The blend valve is a good suspect. Before i bought a new one i would take it apart and see if the hot orifice is blocked.
Like i said, just a guess.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Shower temp fluctuations on pump Skater Plumbing - Systems & Fixtures 4 01-20-2012 06:40 PM
application temperature for vulkem bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 02-25-2007 09:35 AM
any way to set water temperature in an Atwood HW heater? volvophile Water Heaters, Filters & Pumps 2 07-01-2006 07:11 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
Wheel Hub Temperature 74Tradewind Axles 4 07-23-2002 07:26 PM
