Old 01-06-2007, 11:06 AM   #15
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I thought this question would be slam dunk .... No problem Tim, go to isle 12....
Instead I here:
Use the formica
Don't use the formica
Use plastic
Paint it!
Call in a custom fabricator!
Maybe I should stick with the green wallpaper!
I think I'm more confused then when I asked.
-Tim
theVAP - Airstream Podcast
Old 01-06-2007, 11:36 AM   #16
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Information Overload
I think that you want to use Formica. Go ahead and do it. If you protect the EDGES everything should be OK.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 01-06-2007, 11:49 AM   #17
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
formica the 2nd...
my inlaw's shower was redone with it about 8 years ago... no problem since. They did seal the seams though.
Marc
Old 01-06-2007, 11:51 AM   #18
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
I'll third the formica!
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 01-06-2007, 11:52 AM   #19
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Fourth for formica. Now goet out there and do it.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 01-06-2007, 12:46 PM   #20
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Don't use the formica--brittle edges, too stiff, ugh ugh ugh...
I think I'll got to Home Depot and see if they have the plastic.
Zep
Old 01-06-2007, 04:29 PM   #21
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
covering
Originally Posted by Safari Tim
On my Ambassador the shower wall with the fixtures on it is part of the closet.
Originally it has a green waterproof type of wall paper on it. Ugly and needs to go!
What would be a good replacement wall covering for that?
I know, aluminum, or stainless. I was thinking of a laminate like I used for the counter tops but the stuff I have is not rated for shower use.
I thought they made laminates for shower walls, but everytime I ask the Home Depot guys they give me blank stare....
Alsacorp, fx sheeting... coolest product out there for us AS folks.
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 01-06-2007, 10:01 PM   #22
1976 Argosy 24
plumbing embedded in the walls
On the general subject of “shower walls” my Argosy bath was done in an epoxy-like brilliant white.
I wanted to have the miniature marine fixtures appear out of the walls with no apparent supply lines.
The plumbing was embedded in the walls, surrounded with insulation and further protected with electric trace heating good to 40^ below F.
Sergei
Old 01-06-2007, 10:46 PM   #23
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Now it all makes perfect sense....
Nice work there Smokeless!
-Tim
Old 01-07-2007, 07:43 AM   #24
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Hi Tim;
My 60 Ambassador project is slowly coming along. Up to the plumbing inside now. For the shower wall and wall beside the toilet, I used some light green vinal flooring in a bamboo pattern. I have used it before on a house shower with good results. For the trailer it should last OK as it gets far less use.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 01-07-2007, 07:52 AM   #25
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Another possibility for you Tim is to use aluminum. I'm surprised this wasn't brought up as an option. We know that won't leak through the sheet. I put polished aluminum on the end of my bathroom vanity that faces the tub/shower. I suppose I could be coaxed into taking a picture.
FF
Shower stall walls 53flyingcloud Upholstery, Blinds, Walls & Interior Finishes 11 04-07-2016 06:25 AM
First shower in my 1975 Overlander !!! pjtaia Our Community 14 07-05-2015 12:46 PM
Shower walls, what to do? myboyburt General Interior Topics 1 04-16-2004 03:54 PM
Shower head Pahaska 2002 - 2005 International 0 08-24-2002 04:12 PM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 09:03 PM
