Old 02-23-2013, 10:17 AM   #1
'65 Caravel 17'
jlovelady's Avatar
2001 34' Limited
1965 17' Caravel
Lufkin , Texas
Shower Vacuum Breaker in 2000 -34'
I need help in identifying and locating a replace part for the vacuum breaker on my 34' 2000 model AS. The shower is on the roadside. The vacuum breaker on the outlet fitting of the shower leaks a lot. A rubber gasket and a plastic custom washer mount underneath plastic vacuum breaker.
I have been unable to locate this type of shower outlet on the web. The rest of the faucets are Moen. I have presumed that the shower was Moen. Local plumbing stores, rv stores, and the web have not yield results.
I have attached a picture.
jlovelady is offline   Reply With Quote
Old 02-23-2013, 11:02 AM   #2
2002 19' Bambi
Lafayette , California
We just replaced the vacuum breaker for the shower in our 2002 19' Bambi after it did exactly what you are describing. One of the least expensive replacements we found (and bought) is the Hansgrohe External Vacuum Breaker which is listed on Amazon and probably elsewhere. It is a good looking replacement for what you have.
Tim
Tim A. is offline   Reply With Quote
Old 02-23-2013, 06:04 PM   #3
'65 Caravel 17'
jlovelady's Avatar
2001 34' Limited
1965 17' Caravel
Lufkin , Texas
Vacuum Breaker
Thanks Tim, I wil definitely follow up on this one.
