Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 04-20-2007, 07:55 PM   #15
malconium
Profile:  1973 31' Sovereign
Portland , Oregon
Can you suggest a good product?
Can you give us a pointer to a quality check valve of the type that you mentioned? If any of us are going to use one we might as well start with a quality one.
Malcolm
malconium is offline   Reply With Quote
Old 04-21-2007, 05:51 AM   #16
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Camco................
................is the one that I've found to be all metal and the best so far. They are an RV products company, so you should be able to get them at your local RV supply place. Let me know if you can't find them. The ones I stock are all 1/2", and work well for just about all RV uses.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 05-23-2007, 09:55 PM   #17
gregjudy
Profile:  1957 26' Overlander
sandstone , Minnesota
I have been thinking about using a pump, also. Then my gray water tank could sit under one of the twin beds in our 57 Airstream Overlander. Both sinks are high enough that gravity would take care of them. I think that a simple 12v pump (that can run dry), with a switch near the shower would work fine. The small pump could be situated just below the drain. As another poster said, one would want an alternative method for letting the water go out. It is a problem..for sure. Not enough room inside the framework under the shower. Let us know how it works if you do it.
gregjudy is offline   Reply With Quote
Old 05-25-2007, 09:22 PM   #18
malconium
Portland , Oregon
Check out this pump that was recomended to me by Boatdoc. When you get to this website go to page 17 of the catalog. Also notice on the same page that there is a "Grey Water Tank" that is a companion product.
http://www.johnson-pump.com/JPMarine..._2007GB_v1.pdf
I found it for sale at the following website for $186.96. I am sure that there are other marine supply places where it would be available as well. I did not find the Grey Water Tank at this site though so I do not know how much it would cost.
Fisheries Supply Search: Viking%252016
While the pump is a bit pricey it sounds like it would be ideal for the purpose. It would be very unlikely to get clogged up with hair from a shower for example. If you want just an on/off switch I think this pump could be hooked directly to the pipes. If you look on page 16 of the Johnson Pump catalog you will see a somewhat higher capacity pump that has an interesting feature - namely a manual crank handle. That could be a way to solve the problem if the power is out.
Malcolm
Water Pump cycles often Guitars Water Heaters, Filters & Pumps 3 11-19-2002 07:04 PM
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 06:31 AM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 09:13 PM
Water pump has quit roessler Water Heaters, Filters & Pumps 8 08-14-2002 03:02 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
