Old 08-19-2014, 09:04 PM   #15
2002 19' Bambi
Lafayette , California
Teflon tape is not effective for most hand-shower hoses. Flat washers of some sort usually work. If you can't find the missing ones in the back of the car , take the hose to a hardware store and they can probably sell you a couple of washers which will work.
Tim
Tim A. is offline   Reply With Quote
Old 08-19-2014, 09:49 PM   #16
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
There is a black washer fixed to each end of the hose. It feels as if that is not enough. When I tighten the chrome threaded end the hose still has some play in it. On the old hose the threaded ends pull in tight and the single washer does it's job. On the new one it doesn't pull in tight when I thread it tight. I'm gonna try a double washer to see if that will seal things up.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 08-20-2014, 08:03 AM   #17
2004 30' Classic
Hillsborough , New Jersey
Tim A, Thanks for the tip. I placed an order for it. I never did find that part and it is for that is why I "fixed' the problem with glue. wolf146
wolf146 is offline   Reply With Quote
Old 08-20-2014, 08:30 AM   #18
retired USA/USAF
2001 30' Excella
Hummmmm. Maybe it's a New Jersey thing ????
Roger in NJ
TAC - NJ 18
Old 08-20-2014, 09:22 AM   #19
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
Originally Posted by CA Streamer View Post
Did you use some teflon tape on the threads when you put the new hose on? Or perhaps the new hose is missing some vinyl washers?
No Tape, doesn't work and just looks bad. There should be some washers if not head over to a hardware store and get a couple (1 for each end).
By the way, next time we head for Morro Dunes I'll try to give you a message. (we take our Newell MH)
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 08-24-2014, 02:27 PM   #20
retired USA/USAF
2001 30' Excella
OK, Job done. I don't know why but there were 2 loose washers included in the packaging. They are the same size as the washers attached to each end of the flex-hose. I had dropped one so when I installed this I only had one and thought that it was just a misc. washer with no purpose. When I found the 2nd one the Ahhhh light went on. I put one of these washers ( making each end a double washer) at the end and things tightened down nicely and are leak tight. I'm not sure that this was the intention since the instructions do not address this but it worked for me. In the meantime I ordered the piece to put the old shower head back into service if needed.
Roger in NJ
TAC - NJ 18
shower head/spray billiards Sinks, Showers & Toilets 0 03-01-2010 10:52 PM
Spray-in truck bed liner for shower tank? dsakaki Sinks, Showers & Toilets 9 02-14-2009 07:05 AM
Shower head problems Pahaska Our Community 25 08-26-2002 11:43 AM
Shower head Pahaska 2002 - 2005 International 0 08-24-2002 05:13 PM
Shower head Pahaska 2002 - 2005 International 0 08-24-2002 05:12 PM
