Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 10-04-2005, 02:35 PM   #1
Devoman
Airstreamin and luvin it
Commercial Vendor
Devoman's Avatar
Profile:  2005 25' Safari
Panama City Beach , Florida
Shower sealant
I have a spot where just under the rollout screen there is no sealer there.I am wondering what type of sealer is used to do this.Water is running into the bathroom when I would take a shower because of this not being sealed.Thanks
Blue Numbers and Signs
E-Mail Me For Quotes
AIR#8855
WBCCI#6637
Florida Unit #027
Devoman is offline   Reply With Quote
Old 10-04-2005, 03:01 PM   #2
SilverRanger
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
When we picked up our Bambi at the dealership we noticed there were a few spots just as you describe. I believe the technicians were using some type of white silicone caulking. Later on, when they had to remove the shower assembly to repair the cold water supply, they used the same stuff and it looks very nice and is doing the job.
SilverRanger is offline   Reply With Quote
Old 10-04-2005, 11:49 PM   #3
cammur
cammur's Avatar
Roseville , California
Shub sez go for it
Similar problem my 2005 25' Safari. I've been reluctant to caulk these spots, but after reviewing Shub's website (www.newlinebathroom.com) I've become emboldened.
Here is an exerpt from their FAQ:
· Why does the screen leak when the shower is used?
Water can not run to the outside of the screen unless there is a gap in the caulking. Check where the leak is coming from and re-caulk the area. There may be leakage around the perimeter of the screen where the canister and wall jamb are attached to the wall. Caulk the entire perimeter of the screen.
Their installation video recommends a silicone caulk.
cammur is offline   Reply With Quote
Old 10-05-2005, 09:05 AM   #4
Westfalia
Westfalia's Avatar
Profile:  2008 27' International CCD FB
Evergreen , Colorado
Images: 35
Devo, one thing I have noticed with our shower is that the wall where the showerhead is mounted and the rolling door is mounted is not calkued, and there is a gap. On top of that, the wall material there is particle board with a formica cover. I haven't bothered to caulk it since any amount of water will simply rot away the particle board. Who designed this?
Just make sure that you keep all water away from that wall. Make sure the pull out door in fully on the inside of the lip, but I still wouldn't spray directly on the door. Just sit on the the stool, aim the shower head towards the back and enjoy a hot shower!
Chris - Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is online now   Reply With Quote
Old 10-12-2005, 06:44 AM   #5
Devoman
Commercial Vendor
Devoman's Avatar
Sealant
I am wondering what type of sealing calk should I use.Could ordinary silicone be fine.
I could just go to the local Home Depot and get this.
What have you all done and used when fixing something like this?Thanks.
AIR#8855
WBCCI#6637
Florida Unit #027
Old 10-12-2005, 11:29 AM   #6
cammur
cammur's Avatar
Devo,
The door manufacturer recommended silicone, so that is what I used. Haven't had it out for a trip yet so don't know how well it holds, or whether it stopped the leaks. Good luck.
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 08:56 PM
Sealant Products - Exterior & Interior Cat Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 02-12-2003 11:00 PM
First shower in my 1975 Overlander !!! pjtaia Our Community 13 10-30-2002 08:52 AM
Shower head Pahaska 2003 International CCD 0 08-24-2002 05:12 PM
Removing the shower stall - 61 Bambi 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 8 06-16-2002 11:35 AM
