Old 05-23-2007, 10:45 PM   #1
skippervido's Avatar
1976 25' Tradewind
Clay Springs , Arizona
Shower Run From Lavatory Faucet
I just heard of someone who, instead of tearing their shower walls out to replace broken water lines, ran a handheld shower which originates from their lavatory faucet. Since I am faced with tearing out my shower for a similar problem this solution intrigues me. I have found an RV lavatory faucet that has a diverter built in so I guess it is possible.
Has anyone else used this solution? Does it seem like a good alternative to tearing out the shower?
skippervido is offline   Reply With Quote
Old 05-24-2007, 07:07 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Hey skip,
It should work, as most RV showers use the type of faucet that you describe......a hot and cold knob with a diverter valve in the middle. Just get a long enough hose and shower wand and you should be good to go.
Old 05-24-2007, 07:18 AM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
It might not be THAT bad to fix
Hey Skip,
I am in the middle of a coach wide replumb with PEX, I should be doing the shower in the next couple of days. I think it will be akward to replace the plumbing in this area, but here is my plan: cut out the old segments in large pieces and then construct the new segments whole. Thread the new segments into place and connect with the rapid connectors. You might want to keep an eye on my restoration thread to see how it goes http://www.airforums.com/forums/f116...tml#post169149
Good luck what ever you decide and make sure and post pics of the project.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 05-24-2007, 09:48 AM   #4
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Our Safari has a wet bath and the sink faucet works as a faucet and shower head. Really a great setup which is also used in our 1960 Trade Wind! You open the water valves as you would with any sink, get the right temp of water you want, then turn the flow off at the faucet end, pull out the faucet with long flex hose, place into wall holder then push on button and water flows, push off between shower steps, soaping, washing, rinsing to save water and them stays consistant.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 05-25-2007, 03:35 PM   #5
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Skipper,
As promised, here is the report on the shower replumbing job. I have just finished the major parts of the re-plumbing job on my Trade Wind. I assume yours is simmilar to mine. Getting the old plumbing out is a pain, however, once you have it out you can use it to design the new plumbing. I pulled every thing in as large of sections as possible and constructed large segments to go back in. The snap together fittings make it much easier. The second hardest part for me has been standing at the hardware store trying to figure out what parts to buy, looks like I have another trip tomorrow, but thats OK. It is going to be nice having trust worthy pipes for a change. So the short version is this, it may be possible to do your repairs without taking the camper apart. Good luck!
Rodney
and the
My Blog
Old 05-25-2007, 07:13 PM   #6
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
THe PO of my ole rig had finished some of the conversion to PEX. THey did not demo the old copper but left it in place so I will be disecting the old pipe. They had removed the shower faucet and capped the hole and had planned on using the sink faucet for the shower head. I think I will actually reinstall the tub faucet...but that does not look like fun.
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 07-19-2007, 04:20 PM   #7
SLVRSRFR's Avatar
Orange city , Florida
Send a message via AIM to SLVRSRFR
I like that plan rmpray. I will need to completely replace my plumb as well. My shower faucet leaks at the connection to the valve so little pressure makes it to the wand at all. However I will look into replacing system with PEX and leaving original system behind.
SLVRSRFR is offline   Reply With Quote
Old 10-05-2007, 02:49 AM   #8
Lookin' to Boondock
03enduro's Avatar
1975 27' Overlander
Winnipeg , Manitoba
Send a message via MSN to 03enduro
I had a whole bunch of issues with my faucets and the valve bodies being seized. I also discovered that the shower valve body leaked between the valve and the showere supply pipe. Wherever I've changed a fixture, I've cut out the copper, and gone with PEX. Trouble is, a lot of the existing tubing is a goofy size.
03enduro is offline   Reply With Quote
First shower in my 1975 Overlander !!! pjtaia Our Community 14 07-05-2015 12:46 PM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
Shower head problems Pahaska Our Community 25 08-26-2002 10:43 AM
Shower head Pahaska 2002 - 2005 International 0 08-24-2002 04:12 PM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 09:03 PM
