10-11-2018, 04:50 PM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
Shower Replaced
I ended up replacing the shower door in my old 28’ Intl Signature because the door dropped into the bottom frame requiring me to lift it up in order to get the door open. I replaced it with a Sterling pivot shower.
Not unsurprisingly, the shower door also dropped in my ’15 Classic at the beginning of the season. Exactly the same issue as the Intl. Some folks live with this by work-arounds (inserting plastic spacer at bottom of shower door). I decided to try something different.
Here are a couple of shots of my new Stoess cassette shower door. It was made to fit my shower, and it does. Perfectly. After removing the old shower door framing (not for the timid), it took less than 25 minutes to install the new one.
It has a self cleaning squeegee on the back side, and it weighs about 10 pounds. Also, no glass. Around $230.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
10-11-2018, 04:53 PM
Sag Harbor
, New York
I assume you are talking about a "shower door" being replaced?
Peter
10-11-2018, 06:42 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Stoess Cassette is what’s in my 2014 23D they work great.
10-18-2018, 08:49 AM
1976 25' Tradewind
Shelton
Shower door
Hello BAB,
Like the idea of the retracting shower door. Looks great and takes up less room also. So where can I find this product ? did a quick search and did not find it.
10-19-2018, 04:26 PM
2015 30' Classic
Greensboro
, North Carolina
Originally Posted by Toolmanbt
Hello BAB,
Www.stoett.com
_________________
ProPride 3P
AIR# 58452
10-20-2018, 08:19 PM
1976 25' Tradewind
Shelton
Thank you.
10-20-2018, 10:21 PM
Free Range Human
2012 25' FB Flying Cloud
Haines
, Oregon
I’ve been fighting my damned shower door from day one!
Could you detail removal of the existing door? The hinge side is attached with a nasty sealant in my trailer.
01-27-2019, 10:51 AM
2014 25' Flying Cloud
Hampton
, Virginia
Did you ever remove the door? The glass fell out of my door, looking for info regarding the removal.
CHUCK
01-27-2019, 11:07 AM
2008 25' Classic
Full Time
I've already have experience removing my shower door back in 2013 after we purchased our 2008 Classic 25fb. Do you use the inside plastic flashing in your installation? Can you post a photo showing from the inside of the shower?
I'd love to be able to get rid of the door when using the shower. I suspect all Airstream shower stalls are the same dimension for later models with the hallway show.
When you open the door with water on it does it squeege off the water without it getting into the cassette?
Any notice changes in entrance width?
Is there a part number you can share? Did you purchase directly from the manufacturer?
Kelvin
