Old 06-25-2008, 07:32 PM   #1
1970 18' Caravel
Reisterstown , Maryland
Question Shower Removal
Happy Wednesday,
I am new to this forum and have been steaming for 3 years now. I have recently started teh renovation of a 1970 Caravel. I need to remove the shower and have all rivets out so that the top half of the shower compressed down in order to pull it out of the trailer. I can not turn the drain however. I need some suggestion on how to get the shower up off the floor and out the door...
Shiner
Shiner is offline   Reply With Quote
Old 06-25-2008, 10:13 PM   #2
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
A Tough One
You have a challenge there.
38 years of not moving plus plumbers putty can be very tough.
Welcome to the forum, you are in the right place.
Are you replacing with new?
"Talk is cheap, Airstreams are expensive," Wally Byam.
fastrob is offline   Reply With Quote
Old 06-25-2008, 10:45 PM   #3
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
if your 70 is like our 69 tradwind, if you look behind the univolt heat sheild (or if someone has cut an access through the belly pan, you might be able to unscrew the trap so you can get the tub out and deal with the drain from both sides. We were able to get ours out with a standard spud wrench with a few short sections of 1/2 steel pipe cheaters for more leverage.
goransons is online now   Reply With Quote
Old 06-25-2008, 11:58 PM   #4
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
On my '73, there is an access door in the belly pan. You have to drill out the rivets around the access door, then you can reach up in there and remove the p-trap. Good luck and welcome to the forums.
www.nesa.org
Air No. 6427
Old 06-26-2008, 06:26 AM   #5
Over59's Avatar
Putnam , Connecticut
Images: 37
Need to get there from the bottom like they say. You may get an impression of the state of the floor under the shower. What are you going to refinish it with....
Over59 is offline   Reply With Quote
Old 10-25-2008, 11:43 PM   #6
1973 31' Excella 500
Morristown , Tennessee
I don't agree about getting the drain out from under the floor. It is put in from the top with plumbers putty to form the seal. After so many years, it is difficult to turn the drain.
I removed my shower today. The drain was very tight but I used two pry bars placed in opposite holes in the drain. I gently twisted the bars gaining leverage by crossing the bars. I made sure not to break the cross in the bottom of the drain. It worked fine and I got the shower base out of the trailer. Now on to repair the cracks and paint.
Good luck and take your time. Gentle heat may help loosen the plumbers putty.
Joe
Alumin8 is offline   Reply With Quote
Old 10-26-2008, 08:29 AM   #7
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
A tub drain wrench is made to fit it,it kinda looks like a barbell,has different sizes on each end that go down in the the cross bars,then use a phillips screw driver to turn,or if it`s really tight a large pair of channel locks.I`ve removed 50 year old drains from brass drains [ which are a lot harder than plastic to remove] with this tool.In the event the cross bars shear off then it is time to get out the hack saw and cut it internally back to the plastic threads in 2 places.You can get the tool at Home Depot or Lowes. Plumber Dave
easyride is offline   Reply With Quote
Old 11-08-2008, 05:52 AM   #8
1970 27' Overlander
lebanon , Indiana
Images: 8
Drain Wrench
I just saw that Harbor Freight started carring these.
Tim
tchild is offline   Reply With Quote
Old 01-09-2011, 09:11 PM   #9
awolff's Avatar
1966 17' Caravel
Roseville , California
Hello, I'd like to seal the shower in my '66 Caravelle. There are fine cracks on the shower floor, not sure if they lead water yet or not. But just to "refinish it", was wondering what the Shower is made of? Fiberglass? Plastic? Has anyone tried filling these cracks? If so, what did you use? I'm hoping I can fill the cracks with putty or perhaps if it's plastic, use plastic weld, then paint over the repair.
What do you all think?
Alcinda
awolff is offline   Reply With Quote
removal, renovation, shower
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 26 04-02-2017 09:10 PM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 01:00 PM
Shower knob and Toilet Removal jerrodwong Sinks, Showers & Toilets 2 08-18-2006 07:08 AM
Shower pan removal? glacierrunne Sinks, Showers & Toilets 2 07-02-2006 09:45 PM
Shower pan removal in a 79 (rear bath) wdm Sinks, Showers & Toilets 0 06-11-2006 05:44 PM
