Old 09-29-2015, 06:22 AM   #1
2011 19' Victorinox
chester , Virginia
shower problem
How do i repair broken shower drain in a 19 ft victorinox
victorinox12 is offline   Reply With Quote
Old 09-29-2015, 07:29 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
What do you suspect is broken about it? Clogged?
MICHAEL
Old 09-30-2015, 08:02 PM   #3
2011 19' Victorinox
chester , Virginia
it froze and cracked
Old 09-30-2015, 08:26 PM   #4
1979 23' Safari
Wayland , New York
You'll need to get to it under the trailer. You'll either meet to take down tank pan or belly pan to get to where the trap is under the floor to replace the trap piping. Assuming you mean you broke the drain pipe and not the shower pan.
Not fun to get in there.
Piping will be abs sob you'll need abs pieces and abs cement, or pvc pieces and transition cement.
Consider using a HEPVO under there as it doesn't need to be winterized, it should screw straight to the sink drain tailpiece, you'll have to add a male adapter to the pipe on the other end.
Shower leaks behind shower surround Divemaster10 Sinks, Showers & Toilets 6 05-15-2018 03:21 PM
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 26 04-02-2017 09:10 PM
Hand shower post in shower. Jeepers! 1965 Caravel 7 11-01-2014 09:04 AM
To shower or not to shower? urbanfood Sinks, Showers & Toilets 55 07-19-2012 11:39 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
