Old 06-09-2014, 08:18 AM   #1
1993 25' Excella
CLeveland , Ohio
Shower Pan Removal (Pics)
I have removed the screws and drain from the shower pan and everything appears to be loose. How do I take the pan out without cracking it? Do I pull form the top or pull up from the bottom bending the sides in (especially around the knobs).
See pics. Borrowed the photos from another poster who did not seem to get an answer to his question.
I have to replace rotten wood.
Akronguy is offline   Reply With Quote
Old 06-09-2014, 12:55 PM   #2
1993 25' Excella
CLeveland , Ohio
Well, I wound up getting p***** off and gave the shower liner a tug from the bottom and it came out. See pics below. Wasted that time to find out nothing was wrong underneath (Pic One) . Oh well. The reason I pulled it out was that on the other side of the wall the area is rotted (see pic 2). I assumed the wood would be wet in the shower area. I have a fan on it and maybe I can get lucky and not have to move anything to replace the wood.
Pic One:
Pic Two:
Old 06-09-2014, 01:20 PM   #3
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
So, you figure out what the cause was? Worn out caulking ?
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 06-09-2014, 10:34 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Try "Git-rot" or similar product. Saved us a lot of work!
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-09-2014, 10:53 PM   #5
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Just guessing based on photos. 1, cracked wheel well - it's two piece I think, a black piece on the outside and a cream colored one on the inside. It's not uncommon for the black one to crack (according to the VAP). 2, that looks like a hot water heater to the left. Where the HWH exits to the exterior, mine was not properly caulked and leaked during a heavy rain.
I hate leaks, they are sooo hard to find.
DryFly is offline   Reply With Quote
Old 06-10-2014, 06:43 AM   #6
1993 25' Excella
CLeveland , Ohio
Can I remove the cream colored wheel well "easily" to see if the exterior piece is cracked? Can't really see anything from the outside because of the wheels.
Old 06-10-2014, 06:46 AM   #7
1993 25' Excella
CLeveland , Ohio
Went to Lowes this morning and picked up a similar product. Never even thought about it. I love these forums! Hopefully that wll take care of it. Hoping that the wheel well is not cracked as mentioned by another reply
Old 07-31-2014, 09:27 AM   #8
lake worth , Florida
Did you end up replacing the shower liner plastic? I have the exact same setup with holes in the corners and trying to figure out a solution. The plastic has been resistant too all attempts to glue and patch it. Maybe a new shower pan? Has anyone else replaced this?
vreten is offline   Reply With Quote
Old 07-31-2014, 09:41 AM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Update?
Channing
WBCCI# 30676
Old 06-17-2016, 09:25 AM   #10
voxmaestro's Avatar
1990 25' Excella
Foley , Alabama
Send a message via Yahoo to voxmaestro Send a message via Skype™ to voxmaestro
Here is a fiberglass unit from Inland RV that may work. Would LOVE to talk with someone who has actually utilized one of these in their repair.
http://www.inlandrv.com/catalog/prod...3913c29d2765a1
voxmaestro is offline   Reply With Quote
Old 06-22-2016, 09:30 AM   #11
1970 27' Overlander
Little River , South Carolina
Getting ready to take on the same task after this camping excursion is done on Sunday. How did you get the drain out? Just unscrew? I've struggled with stuck drains before and my last AS I had to just cut the plumbing once I got everything loose. Did you use a specific tool to grab the drain to twist it out?
danheit is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Shower Pan Removal Thalweg Sinks, Showers & Toilets 8 09-28-2012 07:41 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
Shower pan removal? glacierrunne Sinks, Showers & Toilets 2 07-02-2006 09:45 PM
Shower pan removal in a 79 (rear bath) wdm Sinks, Showers & Toilets 0 06-11-2006 05:44 PM
