Old 01-31-2019, 03:38 PM   #1
1966 22' Safari
Fredericksburg , Texas
Shower Pan Info
We are trying to complete the interior of our 55 FC. I left the fun part for last, the bathroom. The PO had torn out the bathroom before we took ownership. We are going back with the exact layout as was originally there. The shower is small but doable. Iím at the stage of needing a shower pan. The layout is 26Ē x 24Ē. The challenge is finding a pan with the correct dimensions AND the drain in the correct location. Does anyone know of a custom shower pan company or a DIY method of making my own? I would appreciate any ideas or experiences. Thanks
Bubba L is offline   Reply With Quote
Old 01-31-2019, 04:08 PM   #2
Central , Mississippi
I rebuilt a 55 FC and ended up building an aluminum pan, folded, vulcum'd and buck riveted.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-31-2019, 07:45 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello bubba L: Building a shower in a vintage Airstream is a pain. Maybe the best shower pan is the original tub with a shower curtain. I regret making a shower in my old Trade Wind. A wardrobe may have been a better use of space. I guy can get pretty clean with a sink and a washcloth.
RV shower pans are available. I purchased a 24 by 24 fiberglass one for my project. I would submit the drain location is not all that critical and can be easily replumbed in most cases. I used one of those folding curtain rods to give a guy a bit more room. Head room is marginal in the spherical shaped area that is the rear of an Airstream trailer.
Here is a photo of the pan I purchased. An internet search will provide you some options I'm sure.
David
Name:	1401 Shower Pan Platform-800x600.JPG
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 01-31-2019, 08:21 PM   #4
1966 22' Safari
Thanks for the suggestions. The drain is hugging the inside of the street side main frame member, so relocating options are limited. I thought about a 1/4Ē wooden pan, coating with multiple coats of epoxy, then adding a colored pigment to a final gel-coat. Since Iím getting lazy, finding one ready to install is the way Iíd like to go. Thanks
Old 02-02-2019, 02:09 AM   #5
Libertyville , Illinois
GRIFFORM.com has quite a nice selection of options.
Short563 is offline   Reply With Quote
Old 02-02-2019, 05:44 AM   #6
1977 31' Sovereign
Sunset Valley , Texas
Hey Bubba,
I have a shower pan from my ‘64 SilverStreak. I’ll have to measure it, it may be bigger, but it’s yours if you want it.
Ian
Iansk is offline   Reply With Quote
Old 02-02-2019, 05:44 AM   #7
Following.
My husband and I have been looking at "neo angle" shower pans and shower units, not for a trailer mod, but to add a tiny bathroom in our cabana at one of the regional Airstream parks. However, a similar device looks like it might also work well in that trailer space due to its configuration.
The issues we are having are:
(1) Quality - the neo angles that we have found on the market are not great, and/or
(2) Price - as in, sky high for what is being offered
Anyway, not to hijack the thread but I'm also interested in this topic. What would work in a trailer would potentially also work in a small cabana.
Old 02-02-2019, 05:52 AM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Could you put the shower pan on an elevated platform and run the drain line in the space below it? I know on our 32’ the shower pan is elevated and has a heat vent under it.
Old 02-02-2019, 06:14 AM   #9
1966 22' Safari
Originally Posted by Iansk View Post
Hey Bubba,
I have a shower pan from my Ď64 SilverStreak. Iíll have to measure it, it may be bigger, but itís yours if you want it.
Ian
Ian, thanks for the offer. Even if the pan was the correct size, Iím locked into the location of the drain. But, who knows. Thanks
Old 02-02-2019, 06:20 AM   #10
1966 22' Safari
Originally Posted by Bill M. View Post
Could you put the shower pan on an elevated platform and run the drain line in the space below it? I know on our 32í the shower pan is elevated and has a heat vent under it.
Bill, thatís an idea. With the shower 24Ē deep, the slope of the wall encroaches on the head space. In the 50s Airstreams, the walls had a pretty pronounced curve. I may cut a piece of plywood for the footprint and elevate it until itís too high just to see what I have to work with. Thanks
Old 02-02-2019, 07:57 AM   #11
1977 31' Sovereign
Iíll shoot a couple pics and send them to you, perhaps itíll work, perhaps not. We are close so it would be convenient.
Stand by...
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Pan or no pan bigal1437 Furnaces, Heaters, Fireplaces & Air Conditioning 9 08-20-2017 08:54 AM
Your Bank Info may be public info HowieE Off Topic Forum 6 09-16-2014 12:48 PM
wow info overload/Classic info wanted SterlingSRCH Classic Motorhomes 7 02-15-2013 08:41 AM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
