Old 08-28-2011, 03:29 PM   #1
1978 Argosy 30
prospect , Maine
Shower leaking?
I just got back from a wkend of boondocking. I noticed that when my wife showered, water was heavy dripping or slow running underneath camper. Didn't notice when sinks were being used. Does this mean I have a possible leak in my shower drain piping? If so, what's the best way to fix it? If other possibilities please let me know! Thanks for anybodies help!
thegirouxs is offline   Reply With Quote
Old 08-28-2011, 04:10 PM   #2
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Most Likely a Cracked P-Trap...
... like the one in my 1976 Safari when I bought it in 1996. The GDPO had not winterized the traps, and they all froze including the one under the shower. I'll tell you the quick fix a little later when I have more time.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 08-28-2011, 04:18 PM   #3
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Step 1. Check P-Trap From Inside the Shower
From the shower look into the drain with a flashlight. If there is no water, the p-trap is probably cracked. If you see water it may not be cracked. Stand by for Step2.
Ken L
1966 Tradewind 24
Old 08-28-2011, 05:06 PM   #4
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Step 2. Drop the Pan
That's right. Find a nice work surface in a location where you can spend a few days (or weeks), and drop the pan.
You will need to do a complete visual inspection of the plumbing from beneath while somone above pours small quantities of water down the shower drain.
You will either find a crack in the p-trap or a split in the tail piece that runs from the p-trap to the drain pipe.
Ken L
1966 Tradewind 24
Old 08-28-2011, 05:18 PM   #5
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Step 3. Tells Us What You Find,...
... and we will tells you how to fix it.
Ken L
1966 Tradewind 24
Old 08-28-2011, 06:05 PM   #6
boondockdad2's Avatar
jackson center , Ohio
like the path of water.. check the easiest, most obvious route first.
the two piece shower enclosure seam was the culprit in mine.
the silicone caulk had failed
cleaned it out (picture), and re-sealed
mystery water problem solved!
boondockdad2 is offline   Reply With Quote
Leaking shower 19 F/C Chaps 2009-2015 Flying Cloud 6 01-03-2012 10:20 PM
Replacing Shower Door jmichaelr General Interior Topics 3 07-21-2011 03:47 PM
hand held shower leaking gwillie Plumbing - Systems & Fixtures 4 05-25-2011 06:24 AM
Original Shower Curtain for 1967? star kitty General Interior Topics 3 02-19-2011 08:49 PM
