Old 11-16-2011, 04:35 PM   #1
2008 23' International CCD
Pinson , Alabama
Shower hot water
I have problem described in Airstream video I recently watched. Hot water in sinks but none in shower. Went to take off handle to replace valve but unable to remove screw with standard allen wrench or metrix allen wrench. None would fit!!! Either too big or too small. I had someone else look at it to make sure it wasn't me. Same result. The handle has never been removed since we purchased the Airstream new in 2008. Now what?
RosiesGuy1 is offline   Reply With Quote
Old 11-16-2011, 05:28 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It's an oddball size Allen, like an 11/64" or some such. Expanded Allen wrench sets will have the correct wrench.
Old 12-31-2011, 03:12 PM   #3
racoco's Avatar
1976 31' Sovereign
2007 19' Bambi
Midland , Texas
Glad I found your question -- just came back from a showerless trip (thankfully short) for the same reason; hot water at sink, but not shower.
Are you saying the shower (cartridge) valve needs to be replaced? Haven't seen the Airstream video you're referring to. If that's all it is, I'll be happy.
Coco
1976 Sovereign & 75th Anniv Bambi
TAC TX-3
racoco is offline   Reply With Quote
Old 12-31-2011, 04:25 PM   #4
1974 Argosy 20
Kooskia , Idaho
Yes, you need a wrench set with more sizes. I ran into this when changing out the cartridge in one of my sinks at home. I finally found that I had a T allen wrench that fit the set screw.
Hot water line pacejamr Water Heaters, Filters & Pumps 2 10-03-2011 02:42 PM
345 Shower filled with gray water! sharptalk Sinks, Showers & Toilets 11 07-19-2011 04:30 PM
Any hot water pumps out there? 3 Dog Nite Water Heaters, Filters & Pumps 14 07-05-2011 12:38 PM
No Shower Hot Water KerriO Plumbing - Systems & Fixtures 15 05-29-2011 04:48 PM
Hot Water from Cold Valve txhippiefish Fresh Water Systems 26 04-03-2011 11:05 AM
