Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 05-24-2007, 09:33 AM   #1
Al - K4GLU
Profile:  2007 20' Safari SE
Madison , South Dakota
Shower Head
Does anyone know of a good handheld shower head with water cutoff that really works? The one that came with my 2007 20' Safari doesn't come close to cutting the water completely off. Don't really need anything fancy but something that works unlike the standard shower head.
Al - K4GLU is offline   Reply With Quote
Old 05-24-2007, 09:42 AM   #2
peegreen
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
The shower heads are typically designed to allow a small trickle flow to maintain the temperature of the water in the hose - keeping it warm.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 05-24-2007, 10:03 AM   #3
SilverCottage
SilverCottage's Avatar
Profile:  2007 27' Safari FB SE
LONDON , ON
Our 2007 Safari 27FB had a sticker on the shower head that said it was supposed to drip water so you would be aware the water was still on and wouldn't use the button to turn off the water but would turn the handle to the off position.
I am trying to teach my 2 teenage daughters that they can learn to take a stop-start shower but I don't think it is possible
SilverCottage is offline   Reply With Quote
Old 05-24-2007, 11:41 AM   #4
Tim A.
Profile:  2002 19' Bambi
Lafayette , California
A full shut-off valve is easy. A simple push-on/off valve is available at most hardware stores. Put it on the hose end of a conventional hand-held shower head and attach the hose to the valve. The photo shows how ours is set up.
Name:	Shut-Off Valve.jpg
Tim A. is offline   Reply With Quote
Old 05-24-2007, 01:28 PM   #5
Al - K4GLU
Thanks for the replies. Will look for a shutoff valve the next time I'm in Lowe's, Hoem Depot etc.
Old 05-24-2007, 01:42 PM   #6
peegreen
peegreen's Avatar
That's a Navy shower - at least on a submarine that can only make 10,000 gallons of water a day. When the evaporator goes belly up, no showers.
WBCCI 24291
New England Unit
First shower in my 1975 Overlander !!! pjtaia Our Community 13 10-30-2002 07:52 AM
Shower head problems Pahaska Our Community 25 08-26-2002 10:43 AM
Shower head Pahaska 2003 International 0 08-24-2002 04:13 PM
Shower head Pahaska 2003 International CCD 0 08-24-2002 04:12 PM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 09:03 PM
