Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 02-26-2003, 04:55 PM   #1
tmeagle1
tmeagle1's Avatar
Profile:  1985 34' Limited
Croswell , Michigan
Question Shower Glass/ Curtain
We just purchased our 1973 Land Yacht Sovereign Airstream and the previous owners have hooks and a shower curtain that don't look good. What was surrounding the tub and shower? How could I replace such a thing? Could anyone point me in the right direction and explain to me what should be there or what I should do. Thanks.
Tim Eagle
tmeagle1 is offline   Reply With Quote
Old 02-27-2003, 10:19 AM   #2
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
hi
i have done as your po and you dont want what was there . i have had 3 airstream units and had lots of problems with the shower enclosures . in my motor home the enclosure made soo much noise i took it out, on the road coming home. and installed a shower curtain when i had time. must be a really bad install on the shower curtain. mine looks like it came from the factory . i would improve the curtain installation . you will change your mind when you get a price for the origional enclosure. lol
al
wb13798 is offline   Reply With Quote
Old 02-27-2003, 10:25 AM   #3
wb13798
wb13798's Avatar
just went back and see you have a 73 is that a rear bath??? if it is a rear bath it came with a shower curtain. mid bath is the shower i have used a curtion to replace the plastis enclosure.
i had a 73 like yours ,
al
Old 02-27-2003, 11:50 AM   #4
tmeagle1
tmeagle1's Avatar
Croswell , Michigan
Smile rear bath
It has a rear bath, but they installed some tiny hooks and they are all bunched together and the curain appears not to cover the whole tub. With some advice what should I use for the curtain, since there is roundness in the back? Thanks for the advice.
Tim Eagle
Old 02-27-2003, 12:41 PM   #5
wb13798
wb13798's Avatar
you have the same unit i had . i dont remember having a problem with the shower curtin . if water gets on the shelf it run into the sink. the shelf is molded abs . just send my manual for that unit to a friend on the west coast . wish i had it i could refresh my feeble mind. true the curtain doesnt go all the way around but it did stop the water from getting on the floor. and the little that got on the shelf ran into the sink. i bought a shower curtin from wal mart i had to cut it off (bttom) for it to fit , hang like it should.
nut much else i can tell you . hope i shed a little light on the problem.lol
al
Old 02-27-2003, 12:43 PM   #6
femuse
Profile:
For what it's worth:
we have been living full time since 1996 in our 1974 29' Land Yatch International. It's a rear bath. I suppose they used the same material - cheap looking plastic.
We don't have problems with the shower enclosure. I can see how you can notice noise in a MH, but I think in a TT it's not much of a problem as long as you don't forget to secure the tie that holds the doors folded when traveling. We travel about 8000 miles a year on not always good roads, and we never had any damage to the enclosure.
Chantal
femuse is offline   Reply With Quote
Old 01-02-2007, 11:44 AM   #7
Big Dawg
Profile:  1962 26' Overlander
Bogart , Georgia
can I resurface my shower/tub on a 62 overlander?
Big Dawg is offline   Reply With Quote
Old 01-02-2007, 11:46 AM   #8
Big Dawg
Bogart , Georgia
Is there a shower stall unit designed to fit the rear bath?
I would appreciate anyones experience here.
Big Dawg
Old 01-02-2007, 12:41 PM   #9
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Most likely. I don't recall if a '62 is fiberglass or porcelain though. Several folks here have re-done theirs themselves, maybe someone will chime in.
In the meantime, here's a couple of links to some other's experiences that came out great!
http://www.airforums.com/forum...tub-24616.html
http://www.airforums.com/forum...tion-1293.html
http://www.airforums.com/forum...rts-12563.html
A search will provide some more reading to go through...try keywords like "epoxy", "shower", "bath", "tub" and similar.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 01-02-2007, 10:09 PM   #10
1959newbie
1959newbie's Avatar
Profile:  1959 26' Overlander
Hill Country , Texas
If yours is like my '59, it's neither fiberglass nor ceramic, but some type of hard plastic. I took mine to a professional tub refinisher to sand off the peeling coating that a p.o. had put on, repair an edge crack, and spray with several coats of an epoxy-type coating. It looks great now!
This was one of those things I thought would take way more time -- and probably not look nearly as good -- if I did it myself. And it's going to get a LOT of use, because we'll be living in the trailer for the next year or so. And, because I've been restoring this trailer from the ground up, I have had PLENTY of other things that I've needed to be doing that would not have been so easy to sub out!
Regards,
Lynne
1959newbie is offline   Reply With Quote
Old 01-04-2007, 04:12 PM   #11
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Getting Back to the Original Question
Tim,
If you'll go to this site you can see the folding shower door that was originally in your unit. Look in the photo archive for your year and a couple previous and after - know I saw at least two photos. It unfolds and clips into the the little white bracket on the other side.
In our Ovelander (71) we have a vinyl fan fold that does the same thing but just slides in behind the shower faucet handle. Its not more than 3 or 3 1/2 feet high total.
Vintage Airstream Photo Archives
OHIO - WE ARE THE MOTHER SHIP
Gary
Ganglin is online now   Reply With Quote
shower curtain pattern Lana 1966 - 1968 Safari 30 05-26-2007 03:50 PM
Shelf Doors/ Shower Curtain question srgntpepper 1963 Safari 5 01-06-2004 05:03 PM
Is my shower curtain missing something? overlander76 Sinks, Showers & Toilets 1 08-07-2003 06:12 AM
shower curtain "cap like" grommets Neenm Upholstery, Blinds, Walls & Interior Finishes 0 08-03-2002 02:04 PM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 09:03 PM
Forums Directory
