Looking for shower faucet, handheld shower with hose recommendations. I have a tankless water heater so I cannot go with a low flow system.
Thanks for any recommendations.
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
Are you trying to match an existing cutout in your finished wall? or is it all new? How much wall thickness do you have to work with? If its an open slate, l really like Grohe valves and you cant go wrong with them in my opinion. The thermostatic valves would be over kill so the pressure balance rough valve with trim of you choice would be my pick. You could plumb the outlet to a hand shower and have it on a bar or a hook.
Thanks Alan. Yes, I will be using the same holes in my tub for this - a two handle system- ABS plastic. I have all the room in back of the valve - so that is not an issue. I will check those out.
Greg
